who makes the best thermostat for the ef?
Old May 24, 2008 | 04:12 PM
949's Avatar
949
Default who makes the best thermostat for the ef?
since i got the engine apart i thought i should just replace the thermostat too.
im not sure if im looking for a high or low temp thermostat.
the main idea is to keep the temps low as possible. so would i be looking for a low or high temp thermostat?
also who makes the best performance version, other then oem? ...because i dont think there is an oem version that will keep the temps low.
best=most reliable
Old May 24, 2008 | 04:19 PM
grog's Avatar
Default Re: who makes the best thermostat for the ef? (949)
honda
Old May 24, 2008 | 05:16 PM
shaggyeg6si's Avatar
Near OEM, Mugen.
Old May 24, 2008 | 06:00 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (shaggyeg6si)
Why do you need a lower temp thermostat?
Old May 24, 2008 | 07:19 PM
SIred91's Avatar
Rainman
Default Re: (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">Why do you need a lower temp thermostat?
x2, The OEM Honda is the best made and most reliable. For Honda, this is one
of the parts you don't want to cheap out on. Plus, the motor will run more
efficiently at its optimum temperature, which was engineerd by Honda.
The OEM temp will give you the best mileage and longevity.
Old May 24, 2008 | 08:08 PM
949's Avatar
949
well im sold. ill just replace it with oem.
how long before you guys usually see the oem break down?
im changing it cause i have the engine apart for right now.
i just thought maybe a lower temp would be good for an upgrade. the area im in, socal , is usually very hot and im boosted too.
Old May 24, 2008 | 08:17 PM
SIred91's Avatar
Rainman
Default Re: (949)
I have replaced mine in my CRX twice since the car was brand new. Once for service, and once for motor swap....went B....
I have never seen one fail. But if you are torn down, thats the best time to do it anyway, just for the sake of preventative maintenance.
Old May 24, 2008 | 09:33 PM
949's Avatar
949
i am doing the water pump and oil pump.
do you guys recommend any other preventive maintenance.
Old May 24, 2008 | 09:47 PM
91greenbeast's Avatar
Default Re: (949)
OEM. Honda genuine parts are best.
Old May 24, 2008 | 10:46 PM
Ass$nyper's Avatar
Default Re: (949)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 949 &raquo;</TD></TR><TR><TD CLASS="quote">i am doing the water pump and oil pump.
do you guys recommend any other preventive maintenance.</TD></TR></TABLE> How many miles is on the motor?
T-belt comes to mind if it's apart and checking lash etc.
Old May 25, 2008 | 02:05 AM
Patty's Avatar
Mugen or Spoon low temp thermostat is better than OEM. It is an upgraded OEM design. It will help keep your engine cooler under hard (spirited) driving. OEM is better than the Advance or Autozone crap. For best results use the fan switch and a high press. radiator cap also. I have had mine two years and up to 100 degrees I haven't noticed the drop off in power like I use too.
Old Jun 5, 2008 | 07:36 PM
949's Avatar
949
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> How many miles is on the motor?
T-belt comes to mind if it's apart and checking lash etc.</TD></TR></TABLE>
doing a full engine build.
so i guess after its done i could assume its back to 0 miles. but before this the engine had 75k miles on it.
SiRkid
Honda Civic (2001 - 2005)
Mar 19, 2011 11:07 AM
The-Kid
Apr 25, 2007 08:33 PM
skata89
Oct 20, 2005 06:02 PM
MenaceL.A.671
Jul 27, 2004 06:27 AM
scratchline20
Jul 2, 2003 01:20 PM
