spark plug/oil?
Old May 24, 2008 | 02:07 PM
CR91X's Avatar
Default spark plug/oil?
Today after fixing a few things here and there on the REX (plus put new side moldings )I went to start it and after I did I pop open the hood just to check things out and my spark plug wire/cap was sitting high/had a gap vs sitting nice and flushed the way it should. I know from before that it was not sitting the way it was today. So after I saw it not sitting flushed I took out the spark plug and there was a bit of oil on the spark plug, why? How can I fix this or is it nothing? After taking out the spark plug and cleaning it I clean the plug to the spark plug which was a bit oily form the oil and after i did I put it back but it still sat the same, not flush . So why is this? Or do I just need new plugs? LMK TIA
Old May 24, 2008 | 02:20 PM
phatrick2332's Avatar
usually from the spark plug tubes leaking it will swell the rubber from the plug wires and push them upwards.
Old May 24, 2008 | 02:22 PM
grog's Avatar
Default Re: spark plug/oil? (CR91X)
that actualy happened to me only I can push it down further. I found that the connector at the end of the "boot" had come loose, i guess they are glued in place, you should check that out.
You should check the continuety and resistance of the wire and make sure its okay.
and the oil is coming through the o-ring seals on the VC, get a new VC gasket "kit" it should have the spark plug o-rings.
Old May 24, 2008 | 02:32 PM
CR91X's Avatar
Default Re: (phatrick2332)
yeah that's what it looked like when I was cleaning/looking at the plug ("boot"-Grog) I was gonna put some silicone stuff on it but figure nawh not probably for it so I didn't-only cleaned it and then put it back for the moment...SO I need a new valve cover?? or just valve cover gasket w/ the plug o-rings for the spark plugs? Are they pricey? How much they going to run me? Will I be okay if I just left it/leave it for a while and run it like that or will I run into bigger issues later if I don't fix it?
EDIT: is there anything else besides a VC gasket kit? that I can do like maybe try to put some sort of sealant down there to seal the oil from getting on my spark plugs?LMK
Old May 24, 2008 | 02:42 PM
grog's Avatar
Default Re: (CR91X)
you just need the gasket kit. they arent too much.
and yeah you can get away with not fixing it, but its sooo easy
Old May 24, 2008 | 03:02 PM
CR91X's Avatar
Default Re: (grog)
okay I'll see if I can opt for the kit....but haven't taken off a valve cover yet, but basically it's the gasket that'll be under the valve cover right or something else? Like a spark plus o-ring as you said? and valve cover goes over on top no? How can I fix the plug boot or just get new ones? thanks
so I said I haven't taken off a valve cover yet but do I just unbolt it and that's it? No oil or nothing will come out on me right?
Old May 24, 2008 | 03:32 PM
grog's Avatar
Default Re: (CR91X)
it sounds like you could really use a Helm manual.
and dont start pullin it apart yet, get the parts first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR91X &raquo;</TD></TR><TR><TD CLASS="quote"> How can I fix the plug boot or just get new ones? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote"> I found that the connector at the end of the "boot" had come loose, i guess they are glued in place, you should check that out.
Have you looked to see if that is the cause?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote"> You should check the continuety and resistance of the wire and make sure its okay.</TD></TR></TABLE>
so I said I haven't taken off a valve cover yet but do I just unbolt it and that's it? No oil or nothing will come out on me right? </TD></TR></TABLE>
As long as you do it with the motor off you should be fine
do a search if you need more info.
Old May 24, 2008 | 04:13 PM
CR91X's Avatar
Default Re: (grog)
yeah I do at one point I wanted to order a Helm manual but that didn't happen other things did did a little looking around but I see it's just a o-ring for the spark plug okay...but yeah guess I need to look more on how to take off a valve cover....thanks will see what happens.....
choua01
Mar 19, 2006 06:16 PM
ptran
Jun 17, 2004 06:33 PM
Mefain
Jun 3, 2003 10:15 AM
-Whitey-
Jan 23, 2003 10:49 PM
gixxer6
Oct 29, 2002 01:10 PM
