LS/V "Built" ALL MOTOR SETUP
COMPLETE swap.
no tb or fuel rail but other then that its all there..
I NEED CASH 2 PAY OFF BILLS! YOU WILL NEVER FIND THIS KIND OF SWAP FOR THIS PRICE!!!
NEW PRICE!! 3500 FIRM.. THATS A COMPLETE BUILT SWAP FOR A EG.
the motor has like 150 miles... not even broken into yet. the motor has never been ran or anything its a brand new build!!
i have most paper work. will make 240+
looking for a running eg , da , dc, or ek,
i can install the motor for 300!. in any eg ek dc da ef
or will sell everything for 3500 FIRM. there is more then 10,000 in this set up!
block.
darton sleeve integra block. b18b1. 85mm
brand new OEM 85.mm head gasket
wiseco 12.1 pistons.
eagle rods
arp rod bolts
arp head studs.
brand new OEM type r water pump
brean new oem itr timing belt
Balanced crank
ACL Race bearings
ACL Main bearing
JG header.
Head
dtr big port.
3 angle valve job
supertech valve guides
supertech flat valve's
supertech Springs
buddyclub stage 3 cams
buddyclub cam gears
benen fuel rail
rc 440 injectors.
edelbrock victor x man ported to match head!
ericks racing 70mm TB
Jdm itr tranny... 5th grinds and 3rd pops out
extreme pleassuer plate
2plug clutch
toda flywheel.
eg6 sir 2 shift linkage
polyutherene mounts for eg.
obd1 harness.
jg header
p28 with hondata s200.
http://www.flickr.com/photos/justjoey06/2472112152/
http://www.flickr.com/photos/justjoey06/2458290450/
http://www.flickr.com/photos/justjoey06/2454881153/
http://www.flickr.com/photos/justjoey06/2455708998/
http://www.flickr.com/photos/justjoey06/2454867613/
Modified by Your Name at 2:24 PM 5/24/2008
Modified by Your Name at 5:36 PM 5/24/2008
Modified by Your Name at 5:51 PM 5/28/2008
Modified by Your Name at 5:54 PM 5/28/2008
block.
eagle rods
arp rod bolts
arp head studs.
Balanced crank
ACL Race bearings
ACL Main bearing
JG header.
Head
dtr big port.
3 angle valve job
supertech Springs
buddyclub cam gears
benen fuel rail
rc 440 injectors.
2plug clutch
toda flywheel.
obd1 harness.
jg header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones »</TD></TR><TR><TD CLASS="quote">BUMP FOR A NICE BUILD! </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaNgTiZZy »</TD></TR><TR><TD CLASS="quote"> .... this setup is dope </TD></TR></TABLE>
12's all day all long w/ this setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixfortyfive »</TD></TR><TR><TD CLASS="quote">whys the tranny grind and 3rd pop?</TD></TR></TABLE>
bad shifting i guess lol.... i bought it and it was doing that so ask the old guy
g
fd
fd
g
g
d
