Need help ASAP!!!
fully built single cam turboed crx and i recently baught the car, and i took it for a test drive and so much torque i broke the motor mount and the cam pully wore down and it jumped timing..I then sent the head in to get rebuilt, i got it back and put it on..The issue is that its not starting....we have compression, gas and spark....i've checked all the fuses, non are popped..it turns over and wants to start, but it doesn't..we've timed it several times and made sure that we were on the marks..
have any suggestions, LMK..
Thanx
Thanx
Trans ground is incredibly important unfortunately. Pull a spark plug out and hold it to the valve cover bolt while someone cranks the engine. Is the spark blue or white? Or is it yellow or red? Are you sure the cam is not 180 off? Are you plug wires ran correctly? Remember that cylinder 1 is the drivers side cylinder.
whizdumb
38
Apr 6, 2004 01:43 PM
ophdehEEzY
Mar 14, 2003 07:30 AM
