Prelude Wont Start!! HELP!
i was driving from school yesterday..
all of the sudden i was making a right turn and my car just turned off... lucky enough my friend help me pushed it inside my garage since i wasnt able to start it anymore... checked for gas... i can smell it when it cranks, check sparkplugs, distributor, rotor, sparkplug wires... my battery is new,
im running out of options, is ther any sensors that will make the car not start?.... it cranks and cranks... but when i check the spark plugs they are full of gas.... i have also checked for grounds maybe a ground was faulty but doesnt fix the problem either..... i was thining maybe the TPS sensor... could be screwed... but i dont know...also can you still get gas in the engine but if you have a weak fuel pump.. will the car start... even do like i said my sparkplugs get fuel wet when i checked them.... HELP!
Any help/suggestions will surely be appreciated....
also someone said the main relay?... what exactly is that.. and where would that be... sorry for my ignorance prob know what it is.. just know by its meaning...
Modified by rodriguez at 8:24 PM 5/24/2008
im running out of options, is ther any sensors that will make the car not start?.... it cranks and cranks... but when i check the spark plugs they are full of gas.... i have also checked for grounds maybe a ground was faulty but doesnt fix the problem either..... i was thining maybe the TPS sensor... could be screwed... but i dont know...also can you still get gas in the engine but if you have a weak fuel pump.. will the car start... even do like i said my sparkplugs get fuel wet when i checked them.... HELP!Any help/suggestions will surely be appreciated....
lilsaigon510
Mar 29, 2005 12:10 AM
yusoslo
Sep 28, 2003 12:29 PM
