Fuel injectors
what would be acceptable fuel injectors for a my EF hatch running a PR4 w/ walbro 255 fuel pump, t3/t4 turbo
Modified by HybridHatchEF9 at 1:13 PM 5/24/2008
I would get a set of the dsm 450cc injectors if you have a resistor box, they are oem ( so you know they are good quality) and should work very well for your setup
the size injectors you use really depends on your target horsepower, boost level etcetera etcetera. if you go with larger injectors, remember that you will need to tune your ecu so you dont run super rich at idle.
russianswty
27
Nov 14, 2006 06:30 PM
