ST rear sway bar on 90 crx
Old May 24, 2008 | 10:32 AM
92civicfreak's Avatar
Default ST rear sway bar on 90 crx
is it a direct bolt on? yes or no?
i have search w/ not the exact answer or clarification
Old May 24, 2008 | 11:00 AM
grog's Avatar
Default Re: ST rear sway bar on 90 crx (92civicfreak)
pretty much, everything lines up pretty good. you need to cut (or hammer) the nut off of the shock.
I changed a few things though. Like the small brackets that connect to the end links, it was a little off (which made it pivot a little bit) so i cut the little tab off and re welded it tighter. and the end links ended up being angled so I got some longer bolts and grade 8 washers to move the mounting points of the end link to make it square with the car.
also of the 3 adjustment on it, I could only reach/use 2 of them
I'm happy with it, but I guess it isn't a simple "bolt on" affair. although it is made for the car.
Old May 24, 2008 | 11:08 AM
ok, well i should have menstioned that i'm getting lca's... but my main concern was the brackets that hold the bar up... are the holes for the brackets already there and are threaded? this is my main concern
Old May 24, 2008 | 11:14 AM
grog's Avatar
Default Re: (92civicfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak &raquo;</TD></TR><TR><TD CLASS="quote">ok, well i should have menstioned that i'm getting lca's... </TD></TR></TABLE>
It bolts to the shock with a supplied bracket, so no worries there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak &raquo;</TD></TR><TR><TD CLASS="quote">are the holes for the brackets already there and are threaded? this is my main concern</TD></TR></TABLE>
well all the brackets have simple holes, and everything bolts to the body or has a nut which they supply.
Old May 24, 2008 | 11:26 AM
ok...
but w/ the lca's those 3 or so holes are for the sway bar right? have you or anyone ever set the suspention up like that?
Old May 24, 2008 | 11:33 AM
grog's Avatar
Im not sure i follow you, but some sway bars attach to the LCA's, but this bar attaches to a supplied bracket that attaches to bottom of the shock.
and the "3 holes" I was refering to are on the actual sway bar.
Old May 24, 2008 | 12:53 PM
GSR CRX's Avatar
Default Re: (grog)
the holes on the lca's are not going to be used with the st sway bar. the sway bar has its own holes to adjust the steering feel. as for the mounting points they moun t to the stock tow hooks where as the si's come with there own special bracket. hope that clears it up a little bit more.
Old May 24, 2008 | 12:57 PM
copper rex's Avatar
Grog, do you have the front & rear? Do you like them? I was thinking about getting the suspension techniques or the eibach.
Old May 24, 2008 | 01:09 PM
grog's Avatar
Default Re: ST rear sway bar on 90 crx (copper rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by copper rex &raquo;</TD></TR><TR><TD CLASS="quote">Grog, do you have the front & rear? Do you like them? I was thinking about getting the suspension techniques or the eibach. </TD></TR></TABLE>
I have the rear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">I'm happy with it </TD></TR></TABLE>
I'm sure they are both the same, and I wouldnt waste money on a front sway bar as they are way too thick(which could add alot of understeer). if you must get a front sway bar get a stock one from the junkyard and replace the bushings.
Old May 24, 2008 | 01:16 PM
hey gsr crx. if thats the case shouldn't i buy the st sway bar for an si?
are all the mounting hardware the same?
copper rex's Avatar
Default Re: ST rear sway bar on 90 crx (grog)
Thanx man, rear bar it is.
Old May 24, 2008 | 02:37 PM
anyone...?
Old May 24, 2008 | 02:39 PM
efsublime's Avatar
okay so if you have aftermarket lcas with the three holes for adjustment, which bar do you buy that will work with them?
Old May 24, 2008 | 02:57 PM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak &raquo;</TD></TR><TR><TD CLASS="quote">hey gsr crx. if thats the case shouldn't i buy the st sway bar for an si?
are all the mounting hardware the same?</TD></TR></TABLE>
I believe they only sell one sway bar, and all the models are the same in that area, except for the 88's LCA's and shocks.
Old May 24, 2008 | 03:26 PM
copper rex's Avatar
Default Re: (grog)
grog is right. 88-91 crx are all the same (every submodel). only difference is for 88, it requires an adapter kit.
Summit racing sells the set for $244, or just the front for $139.
http://www.summitracing.com it has pdf instructions with pictures on the page
Old May 24, 2008 | 03:49 PM
i've been sitting on the idea of getting one long enough...... baught..... thanks for the tips
s13hero
May 7, 2011 03:58 PM
Ritchie
Suspension & Brakes
26
Oct 16, 2010 09:29 PM
gonmaro
Suspension & Brakes
Apr 8, 2009 05:31 PM
essex
Apr 14, 2003 10:54 AM
