OBD-II to OBD-I conversion.
Old May 24, 2008 | 10:31 AM
97BB6Type-SH's Avatar
Default OBD-II to OBD-I conversion.
I own a 5th gen type-sh. i searched and read all the threads for conversions. my plan is to convert to OBD-1 and chip a p28. Now i see in every thread the OBD-I dizzy is a must. but in some threads i see you also need OBD-I injectors and resistor box. My question is, are the resistor box and injectors neccessary and if not whats the differnce of not having them, how will it affect the car? thanks
Old May 24, 2008 | 10:36 AM
98vtec's Avatar
moderator emeritus
Default Re: OBD-II to OBD-I conversion. (97BB6Type-SH)
no.
where did you see in every thread that it was said to use the OBD1 distributor?
conversion harness + ecu + tuning. thats it.
Old May 24, 2008 | 10:44 AM
Default Re: OBD-II to OBD-I conversion. (98vtec)
well i also saw it said i could rewire my OBD-II distributor, but i think i rather just buy an OBD-I. unless your saying it is not necessary?
Modified by 97BB6Type-SH at 11:54 AM 5/24/2008
Old May 24, 2008 | 10:54 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
conversion harness + ecu + tuning. thats it.</TD></TR></TABLE>
Old May 24, 2008 | 10:55 AM
ok man i trust in you. thanks
Old May 31, 2008 | 02:26 PM
Also, i believe my knock sensor is messing up because sometime it sounds like a harley and back fires at idle like it if were choking, and it hesitates from 2-3k rpm like if i were on a bumpy road. it use to throw a misfire C/L but that went away on it own. so i know its a sensor. but ive seen the knock sensor for like $150. if i go over to obd-1 will the knock not be necessary anymore? i was told it would no longer be necassary and my car would run good? true or false?
Old Jun 1, 2008 | 02:42 PM
bump
prionailurus
Mar 25, 2008 12:28 AM
type Gendy
May 9, 2005 12:04 PM
Chynito_JDM
Mar 29, 2005 02:28 AM
91lsteg
Jan 9, 2005 11:43 AM
BB6-213
Jun 22, 2004 12:01 AM
