2 Big Power Amps JL/Hifonics Almost New!! CHEAP!!!! -PICS!!!!
Old May 24, 2008 | 08:47 AM
lilxdrifterx06's Avatar
Default 2 Big Power Amps JL/Hifonics Almost New!! CHEAP!!!! -PICS!!!!
Like topic says i have 2 barely used Car audio amps!!!!!IN Perfect working condition! These two amps will blow windows out.. I had all infinity components with a w7 13.5!! And these amps where amazaing will not be dissapointed one bit!!!I even still have the gain controller ****!!
Asking Price $350
WILL TRADE: 94-2000 Integra PArts, Some 15-16 rotas or watever!!! OR A Verizon Voyager or Glyde!!!
CONTACT INFO:
(626)646-7075 CALL OR TEXT!!
1: JL Audio 300/4
In perfect condition basically brand new!!!!!
(Very Underated Amp)
Rated Power(stereo): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged): 150 W RMS x 2 @ 3 ohm-8 ohm(11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm
S/N Ratio*: >108.5dB below rated power
Frequency Response: 5 Hz - 30 KHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per. ch./50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
Differential-Balanced Input Topology: (2 pair of inputs)
Front Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
Speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
2: HIFONICS BXi 1606d CLASS D BIG POWER AMP!!! (1600 WATTS)
I used this amp too push a W7 it was AMAZING!!!! (2 80amp Fuses)(2GUAGE POWER TERMINALS)
RMS @ 4-Ohm: 1 x 550-Watt
RMS @ 2-Ohm: 1 x 1100-Watt
RMS @ 1-Ohm: 1 x 1600-Watt
Hifonics New Illuminated Heat-Sink Design With Blue LED Light Pumps
Hifonics Blue Illuminated Logo
Maxxsonics Illuminated "M" End Panel Logo
Heavy-Duty Ultra-Fi™ MOSFETS
Highly Efficient Super D-Class Amplifier Circuitry With Oversized MOSFET Output
Fully Adjustable Accu-Cross™ Crossovers
±18dB Variable Bass Equalization @ 45Hz
180° Variable Phase Control (15 to 35Hz)
Dash-Mountable Bass Remote Control Included
Variable 24dB Subsonic Filter
Brutus Pulse Wave Modulated MOSFET EXVP (Exponential Vari-Power Supply)
Twin-Turbo Torroid Coil Design
HSMD Hifonics Surface Mount Design
Balance Line Inputs for our 18-Volt Line Drivers
RCA Line Output for Amplifier Daisy Chaining
Gold Oversized 2-Gauge Power Connectors
Power From The Gods Included
Asking Price $350
CONTACT INFO:
(626)646-7075
Old May 24, 2008 | 07:11 PM
Default Re: 2 Big Power Amps JL/Hifonics Almost New!! CHEAP!!!! -PICS!!!! (lilxdrifterx06)
Old May 25, 2008 | 11:17 AM
up
Old May 25, 2008 | 02:20 PM
done up bb6's Avatar
would you trade for some HIDS? for the JL amp
Integra2316
Apr 7, 2007 05:34 PM
Aloha04MSM
Mar 22, 2006 07:46 PM
NUBREED
Apr 6, 2005 12:05 AM
CHONCH
Sep 10, 2003 09:43 PM
ilikemyaccord
Audio / Security / Video
May 27, 2003 01:51 PM
