Reverse and Tag light issue
For some reason my reverse and tag lights do not work. This happened after I did a B series swap and the wires for the tranny are wired right, and the fuses or bulbs aren't blown. Are both of the wires from the tranny supposed to have constant power or not? Has anyone else ever had this problem with the reverse and/or tag lights? And I already searched but I got no results.
my license plate lights werent working a while back and the connection came loose near the access panel for the brake lights, check that out.
as for the reverse lights, make sure the sockets arent corroded, and test the voltage at the socket (with the reverse lights on)
skimeast1982
Oct 24, 2005 11:28 AM
esp4life
May 9, 2005 08:38 AM
