fuel pump problem
Old May 24, 2008 | 12:26 AM
crx_xxx's Avatar
Default fuel pump problem
well i just put in a d16z6 motor into my 91 crx si I went to fire it up and it made some weird nosies kinda like my starter was not good maybe? but then after i pusht the gas pedal a few tims it fired right up and only ran for like 3min!!! so i went over eveything and lookt at my fuel presure gauge and it dropt rigth down to 2psi??? sooo i dont think my starter would have anything to do with this! all i can think of is that my pump packt it in or maybe can it be my main relay?? i dont know i am pretty lost right now! so if anybody can help me out that would be awsome!!
Thanks guys!
Old May 24, 2008 | 02:25 AM
Thrizzle's Avatar
* B A N N E D *
Default Re: fuel pump problem (crx_xxx)
Start w/ diagnostics.
Check power @ the Fuel pump w/ someone cranking the key.
If you have power while cranking.. then the relay is working and the other is not.
gamajohn
17
Feb 14, 2014 10:41 AM
ef8sleepr
May 4, 2011 01:54 PM
quilksilver
Feb 27, 2009 05:41 PM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
RedRocketCRX
Jul 22, 2004 12:06 AM
