Verryy annoying sound
Old May 23, 2008 | 10:59 PM
biggjerryc's Avatar
Default Verryy annoying sound
Assuming we all know what it sounds like when a heat shield rattles(like the common one that rattles on the cat).. im getting that sound but, none of the heat shields are loose. ive even had someone rev the motor while i hold the heatshields in place. Im still hearing the noise. I was wondering if the baffles in the resonator could have broke. its a greddy evo 2 catback system but its only been used for maybe 6 months? Any other ideas. and its only really noticeable when driving... any ideas?
Old May 24, 2008 | 07:34 AM
Daammnn's Avatar
dont know what to tell you.. does it do it right at around 3500 rpms? if so its the heat shield under your car ha. it shouldnt be the hard to locate a rattle noise on your car.
Old May 24, 2008 | 08:28 AM
mattblack's Avatar
Yes the baffles can break off inside and also chamber walls inside of the muffler can break off. I am having this problem with a World Sport right now. If you already checked the heat shields you can its probably in the muffler or resonator.
I have something broken off in my muffler and it rattles loud when ever you let off the gas after revving for a shift. I am cutting it off and welding on a new one in a few days.
The exhaust might also be loose and vibrating on the undercarriage somewhere.
Old May 25, 2008 | 08:35 AM
biggjerryc's Avatar
Default Re: Verryy annoying sound (biggjerryc)
ill check some more today but, the wierd thing is that, i revved it with the exhaust on and it did it. then i unhooked it right after the resonator and it didnt do it. If i take the heat shields completely off, will that hurt anything in the long run?
Old May 25, 2008 | 07:06 PM
mattblack's Avatar
Probably not, I know people who have taken their heat shields off. I can't say that I'd recommend it.
I think there are some spray on undercoatings that act as a heat shielding also.
Sounds like there might be something broken in your muffler, either that or its vibrating off the undercarriage. I you put it back on and hold it away from the car and have someone rev the motor you should be able to hear exactly where the sound is coming from.
mikecp
May 20, 2010 09:21 PM
lv6l
Sep 29, 2005 07:10 PM
gaydm.accord
Oct 28, 2003 08:51 AM
Jago
Sep 16, 2002 07:40 PM
Spartanic
Mar 30, 2002 10:31 AM
