CLUSTERS
Old May 23, 2008 | 08:26 PM
93b20z's Avatar
Default CLUSTERS
wat can i use in my eg other than an eg cluster??... and wirings.. how do i do that??.. ive seen s2k in an eg?... how??
help??
Old May 23, 2008 | 09:09 PM
jimmy o.'s Avatar
All clusters other than civic cluster require some modifacation to fit and work. There is a write-up in the FAQ's about how to put a teg cluster in a civic. Do you just want a cluster with a tach?
Old May 23, 2008 | 10:29 PM
austinkli's Avatar
Default Re: CLUSTERS (93b20z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93b20z &raquo;</TD></TR><TR><TD CLASS="quote">wat can i use in my eg other than an eg cluster??... and wirings.. how do i do that??.. ive seen s2k in an eg?... how??
help??
just about anything COULD technically go in, just depends on how it will look in the end and how much customization you are willing to do. only another eg cluster is going to slide right in, anything else including the s2k cluster is going to require some customization.
Old May 24, 2008 | 12:54 PM
area608EG's Avatar
for the most part do you just want a tach? or a lit up needles? if yo ujust want a tach u just have have d15b you want an lx cluster, if ur running a 16 u want an EX cuz the red line is higher. other than that trying to fit anything other that is a only a dremel away and alot of trial and error, and a cluster f#@$ of re-pining. Either way whatever you pull make sure you try to cut the harness it'll save time.
Old May 25, 2008 | 08:20 AM
austinkli's Avatar
Default Re: CLUSTERS (area608EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by area608EG &raquo;</TD></TR><TR><TD CLASS="quote"> and a cluster f#@$ of re-pining.</TD></TR></TABLE>
ha ha, you said replacing the cluster is a cluster [freak] of re-pining, ha ha. i lol'ed.
Old May 25, 2008 | 08:43 AM
93b20z's Avatar
Default Re: (jimmy o.)
yes of course.. but a teg??.. not a teg's something "cool"
Freeltec
Aug 20, 2009 07:54 PM
1slammed92
Mid-Atlantic (Sales)
Feb 27, 2009 11:45 PM
doubleoazn03
Nov 9, 2008 07:41 AM
