EF (dx) upgrading brakes from DA (gsr)
story: i own a DA, it blew a fuel line in the engine bay and it caught on fire. so now i have a parted out DA
i also have a EF (dx) and im switching as many parts as possible from the DA. i already switched the rear traling arms and runs fine.
NOW---- i am wanting to get the front disc brakes from the DA into the EF. only reason is beacuse i recently had purchased cross drilled slottered rotors for the DA. so i want them on th EF.
as much as i hate to post a new thread (full for flamers) i couldnt fins that much helpful information. ALL i want is the rotors and calipers from the DA and the tokiko shocks.
my question is: exacly what else do i need/recomend for a legit ride. what proportioning valve to use. can/should i use any other suspension parts??? and is it also a "bolt on" (what hub....) thank thank thank you HT
thank you
Modified by v-motion at 9:09 PM 5/23/2008
thank you
DA calipers wont fit on civic knuckles. you have to use the whole DA knuckle. using that knuckle supposedly they give a more positive camber which is only good if you have a lowered car.
i suggest just using the whole suspension off the DA such as the brake booster, master cylinder, prop valve, and both front and rear disc brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR CRX »</TD></TR><TR><TD CLASS="quote">using that knuckle supposedly they give a more positive camber which is only good if you have a lowered car.
THIS IS 100% INCORRECT INFO...LOOK AT THE THREAD IN THE FAQ! THERE IS NO DIFFERENCE AS FAR AS CAMBER!
i am lowering from OEM stock to exacly 1 1/2" drop. ....... and i am guessing that DA knucles, booster, MC, prop. valve and new brake lines are my list of parts.??.?? with no camber and toe ????
Nooch
Jul 14, 2010 04:14 PM
949
Oct 17, 2008 12:27 AM
I heart My EF Sedan
Sep 7, 2007 11:38 PM
sasinorm01
Sep 7, 2006 06:37 PM
