b16a able to smog?
Old May 23, 2008 | 04:04 PM
hasaan51's Avatar
Default b16a able to smog?
i have a jdm b16a in a 99 civic sedan. i was wondering what i needed to make that motor bar'd and smoggable. any advice would help. thanks
Old May 23, 2008 | 04:50 PM
wonder squirrel's Avatar
Default Re: b16a able to smog? (hasaan51)
It needs to be a 99 or newer engine with all the original emission equipment intact and working.
Old May 24, 2008 | 02:34 PM
hasaan51's Avatar
Default Re: b16a able to smog? (wonder squirrel)
i got the car with the b16a swap in it. its running a p30 ecu with the check engine light on and the guy i got it from said that i will need a new engine harness. how can i tell if the motor is obdI or obdII? I should be able to use the 99-00 si harness right? i want to change the title and when they asked to smog, i want to be able to bar it and pass smog. still new to this b-series swap and wiring so any help would be appreciated. thanks!!
abadkevin
38
Aug 21, 2013 10:12 AM
Jason P
Mar 29, 2009 08:14 AM
Wanza
Feb 16, 2009 09:16 AM
X93siX
Oct 29, 2007 03:36 PM
CRiX
20
Sep 25, 2001 11:10 AM
