OBD0 B16A injector O ring
Old May 23, 2008 | 11:49 AM
MikeFabRex's Avatar
Default OBD0 B16A injector O ring
I searched and couldn't really find an answer. I'm planning on buying an aftermarket fuel rail & intake manifold, and I'm going to need new upper/lower injector O rings. I'll be using my stock OBD0 B16A injectors..when I go to Honda, what vehicle should I tell them so I get the right part? I usually tell them I have a 2000 Civic Si. Any info would be appreciated. Thanks everyone!
Mike
Old May 23, 2008 | 02:24 PM
Crx Jimmy's Avatar
Default Re: OBD0 B16A injector O ring (MikeFabRex)
the b and d series injectors are the same so the o -rings should be the same as well
you can also buy a large o-ring assortment from harbor freight for real cheap, probably lees than the couple ones from honda would cost, and you will have hundreds extra left over. I have one and use them for the dizzy o- ring, injector o-ring ect.. I think they have ones made of different rubber compounds I got the green ones, they are safe for oil/fuel
Old May 23, 2008 | 04:19 PM
zrickety's Avatar
Default Re: OBD0 B16A injector O ring (Crx Jimmy)
i am ordering my o-rings now...thanks jimmy! does anyone know what honda uses? are they metric o-ring sizes??
Old May 24, 2008 | 10:52 AM
MikeFabRex's Avatar
Thanks for the reply man. I saw the Harbor Freight kit in someone else's thread. There's actually a Harbor Freight 15 mins from my house. We'll see, I may just go to Honda..
Turbo_Mike
10
Apr 12, 2009 08:18 AM
Turbo_Mike
Apr 4, 2009 09:07 AM
turbotime
Nov 17, 2006 05:25 PM
type Gendy
Feb 26, 2004 08:27 AM
Hybrid Invasion
Mar 10, 2003 06:49 PM
