Question about oil for B18B with 160K on the motor
Old May 23, 2008 | 08:38 AM
94DCTeg's Avatar
Default Question about oil for B18B with 160K on the motor
Whats going on members, im sure this has been covered but i cannot seem it locate anything in the search area, i have a 94 Integra LS, with Crane stage 2 cams, 4-1 header, oversize TB, now with the milage that is on my motor not sure exact milage but its 160,xxx ish, compression is great, right now i run an OEM Honda Oil filter, and Mobil 1 5W30 Motor oil, it dosent burn or leak any oil, would the suggestion be to switch to a 10W30 or should i stay at 5W30 ??
Thanks
Old May 23, 2008 | 08:54 AM
Rickdrizzle's Avatar
I don't know, but my gsr has close to 200k and it was smoking at very high rpm. That changed when I switched to 10w-40.
Old May 23, 2008 | 09:29 AM
94DCTeg's Avatar
Default Re: (Rickdrizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle &raquo;</TD></TR><TR><TD CLASS="quote">I don't know, but my gsr has close to 200k and it was smoking at very high rpm. That changed when I switched to 10w-40.</TD></TR></TABLE>
so stick with 5W30
Old May 23, 2008 | 09:30 AM
allmotorek8's Avatar
i have 262k in my daily and i use castrol 10w40 drive hard and have no problems and for my other dc it got almost 300k and i use castrol synthetic 10w40 and still have no problems or smoke. hope it helps
Old May 23, 2008 | 09:54 AM
Default Re: (94DCTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DCTeg &raquo;</TD></TR><TR><TD CLASS="quote">
so stick with 5W30 </TD></TR></TABLE>
I meant it smoked when I was using 5W30. It stopped when I switched over to 10w30
Old May 23, 2008 | 10:34 AM
94DCTeg's Avatar
I meant it smoked when I was using 5W30. It stopped when I switched over to 10w30</TD></TR></TABLE>
got ya... thanks <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorek8 &raquo;</TD></TR><TR><TD CLASS="quote">i have 262k in my daily and i use castrol 10w40 drive hard and have no problems and for my other dc it got almost 300k and i use castrol synthetic 10w40 and still have no problems or smoke. hope it helps </TD></TR></TABLE>
Thanks and that has helped... i will stay with 5w30 for this oil change and then change it up to a 10W30 Synthetic !!!
Old May 23, 2008 | 11:18 AM
Nightwolf1772's Avatar
Ive got a 1994 Ls also but we use 20w50 in it I dont know why the previous owner ran it but I guess beacuse of the engin mods done to it
Old May 23, 2008 | 11:32 AM
just remember once u go synthetic you cant go back to red oil
Old May 23, 2008 | 02:15 PM
TOO MUCH TORQUE's Avatar
Default Re: (allmotorek8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorek8 &raquo;</TD></TR><TR><TD CLASS="quote">just remember once u go synthetic you cant go back to red oil </TD></TR></TABLE>
do not listen to this person.
Old May 23, 2008 | 06:16 PM
inspiration's Avatar
Default Re: Question about oil for B18B with 160K on the motor (94DCTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DCTeg &raquo;</TD></TR><TR><TD CLASS="quote">Whats going on members, im sure this has been covered but i cannot seem it locate anything in the search area, i have a 94 Integra LS, with Crane stage 2 cams, 4-1 header, oversize TB, now with the milage that is on my motor not sure exact milage but its 160,xxx ish, compression is great, right now i run an OEM Honda Oil filter, and Mobil 1 5W30 Motor oil, it dosent burn or leak any oil, would the suggestion be to switch to a 10W30 or should i stay at 5W30 ??
Thanks </TD></TR></TABLE>
It's true about once you use synthetic you can't go back. If you do then the chemicals that help seal your engine better would get worn out and eventually will make your engine leak. You can change your motor oil at 5,000-6,000 miles or you can go more. At 3,000 miles you just need to change your oil filter and just add a quart of oil.
Old May 23, 2008 | 06:56 PM
PaChiLa Leader's Avatar
are you sure? i have switched back and forth on my stock EK and never had any problem .. car runs fine, burns almost same amount of oil on synthetic or non-synt (during oil changes, just only a bit)
Old May 24, 2008 | 02:05 AM
Default Re: (PaChiLa Leader)
oh word ight my bad i aint know that but i love synthetic and im over 300k with no problems
Old Jul 6, 2014 | 11:06 AM
magill13's Avatar
Thats horrible
Old Jul 7, 2014 | 06:29 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
There is absolutely no truth to the "once you go synthetic, you can't go back" theory. It's 2014. How do people still believe that?
Also...if OP is having good luck with his current oil/filter combo....why change it all of a sudden?
10W30 is not thicker at operating temp than 5W30. It's only thicker at start up and under operating temp.
Old Jul 7, 2014 | 05:41 PM
JDaM_teg's Avatar
This guy!! well said
Old Jul 7, 2014 | 06:43 PM
m4xwellmurd3r's Avatar
Yay someone else who understands how oil works lmfao.
Big plus side to synthetics is they have very kittle viscosity modifiers so as the additives break down their operating temp viscosity stays about the same.
Conventional starts out as the lower rating, and the modifiers thicken it while at operating temp. As the additives break down the oil begins to thin out
5w30 turns to almost straight 5 weight
Synthetic 5w30 remains 30 weight at operating, but doesnt thin to 5 weight when cold like it originally did.
Thats part of the reason why synthetics last longer
prwil3030
May 24, 2006 12:09 PM
bigstevo106
Apr 25, 2006 06:00 PM
eg6_rick
74
Jun 2, 2005 09:53 AM
Asway
14
Aug 19, 2004 11:15 AM
DelSolSi93
Nov 8, 2003 10:28 AM
