yonaka header
Old May 23, 2008 | 08:00 AM
Krayzielix's Avatar
Default yonaka header
anyone running the yonaka itr replica header thats sellin here on honda tech?..if so..hows the quality and fitment?
Old May 23, 2008 | 10:29 PM
prettylew's Avatar
Default Re: yonaka header (Krayzielix)
im not running one, but yonaka is a generic name like blox or megan. but just from lookin at that pic it looks INCREDIBLY restrictive at the collector.
Old May 24, 2008 | 02:33 PM
Chizle707's Avatar
Default Re: yonaka header (prettylew)
lmao, that header is GAYNESSSS!
Old May 24, 2008 | 05:12 PM
junkyard racer's Avatar
that header looks like the same header he bought off of ebay for $35 shipped, new. the flange is totally [freak]ed up on it.
Old May 25, 2008 | 10:18 AM
Krayzielix's Avatar
Default Re: (junkyard racer)
aite thanks for all the info..guess i wont be getting it
Old Feb 10, 2011 | 06:36 AM
Dotz's Avatar
Hi guys, i need some information about this brand: yonaka, they have one header, the black edition.
2.5" collector flange is restrictive?
http://www.redlinemotive.com/store/y...jdm-header.asp
Regards from Portugal
Old Feb 10, 2011 | 10:24 AM
mouab18c1's Avatar
Waste of money! Get a RMF replica narrow header from VtecKidd
Old Feb 10, 2011 | 12:14 PM
gashybrid's Avatar
had two customers buy them, one fit perfect and worked well, the other wouldn't even match up with the head flange....
Old Feb 10, 2011 | 12:38 PM
hood ride eg's Avatar
they should make a " rmf drag " replica.
Old Feb 10, 2011 | 01:53 PM
The Ogre's Avatar
i bought lugs from em. Same **** as every other ebay company.
Old Feb 10, 2011 | 04:34 PM
N/A's Avatar
N/A
Purpose Built
Deff not the same as the ebay header if you look at it closely, I like how the heat shields can be mounted on it.
On the other hand tho, there are much better bang for your buck headers
Old May 27, 2011 | 05:33 PM
deary09's Avatar
how is the ground clearance on them? I want to get one because i want to look as stock as possible. http://www.redlinemotive.com/store/y...jdm-header.asp
Old May 28, 2011 | 07:36 PM
mtber's Avatar
If you are trying to make power and stay on the cheap I would go with a private label header: http://www.phearable.net/shoppingcar...70_71_102.html
Old May 29, 2011 | 07:46 AM
tagperformance's Avatar
400-500 is not cheap when your comparing it to a 200 dollar header.
Old May 29, 2011 | 11:14 AM
vtec8200's Avatar
It is the same as a JDM ITR header, just badly made. It is not a real 2.5" collector, there is another tube inside it, around 2.25". This header can be ported at the head flange for true fit and anti-reversion and the collector can be cut and replaced with a tru 2.5" ID pipe for a 2-5 whp gain depending on the setup, ground clearance is ok.
Old May 29, 2011 | 12:14 PM
AllShowNoGo727's Avatar
Wow John I didnt even realize you sold parts like that.
Old May 29, 2011 | 10:25 PM
m_shake's Avatar
I ran one that was port matched and had the collector opened up to true 2.5". On my b18c1 w/usdm itr pistons, itr cams, S2 intake mani, opened up crx sir airbox, ported head and rsr exhaust it made 178hp on blacktrax's dynopack. Ground clearance was ok but none of the heat shield mounts lined up
Old May 30, 2011 | 07:57 AM
deary09's Avatar
yea alot of people say this header doesn't line up, thats pretty much dumb. I have a rmf narrow style header but wanted to look stock. I might just go with the oem itr header.
Old May 31, 2011 | 02:58 PM
m_shake's Avatar
Yeah oem is the way to go, wish I woulda the first time around. Don't forget to mod the collector end
milanoteggy
Jul 3, 2013 10:30 AM
RedneckRicer
Apr 3, 2008 12:05 PM
da'ee
Feb 14, 2005 01:03 PM
