Custom catch almost done! Baffling?
Old May 23, 2008 | 06:04 AM
GT35R_EF's Avatar
Make mine whatever you want
Default Custom catch almost done! Baffling?
Alright so i'm posting this up for my brother, this is the first time he's ever made a vent/catch can (For the car we are building together). This will be for the two -12 lines out of the valve cover. Here are a few pictures of the catch can. The first couple is just it tacked up with the top being cadboard for fitment. and the rest are it welded without the top welded yet...
I'm trying to figure out what we should do for baffling. This WILL NOT recirculate to the oil pan and will be emptied. I got a couple ideas how I want to do it, but wanted to see if anyone had any recommendations that will work well. Thanks
Old May 23, 2008 | 06:17 AM
AssItch1's Avatar
Default Re: Custom catch almost done! Baffling? (GT35R_EF)
nice!! very nice...
cant tell you anything about baffling though
Old May 23, 2008 | 08:44 AM
GT35R_EF's Avatar
Default Re: Custom catch almost done! Baffling? (AssItch1)
haha thanks for the compliment man
Old May 23, 2008 | 09:40 AM
qksl2's Avatar
I just welded in some aluminum plates that divert the gasses down as soon as they get in the can, then into a cube that has steel wool. Helps separate the oil and then let the fumes vent out the top.
Ian
Old May 23, 2008 | 12:21 PM
ebydrc's Avatar
Banned
is it just me or does that alu. look crazy thick?
Old May 23, 2008 | 03:23 PM
welfarepc's Avatar
i run an open vent catch can, that drains, with no internal baffling and ive never had any oil problems on the dyno or street...
since you are going manual drain, add some baffling over the air exits and maybe one laterally to stop it sloshing
i would put the filters higher as well if you can as well
curious why you dont want to recirulate?
Old May 23, 2008 | 03:47 PM
yee SERIOUS's Avatar
Default FV-QR
pretty nice. that aluminum is pretty thick. lol
Old May 23, 2008 | 05:24 PM
GT35R_EF's Avatar
Yea the aluminum is a little thicker than usually used, for some reason it's looks REALLY thick in the pictures but it's not bad at all in person.
And for the guy wondering about recirculation I didn't want to drain to the pan with steel wool in it and also only have two return slots on the moroso pan. One is for Turbo return, other is going to be oil temp. I would drain back if it was something that would see the street a lot more often, but it will mainly stay at the track, and we have a quick & easy solution to drain it.
Old May 25, 2008 | 03:25 PM
snowseeker's Avatar
Default Re: FV-QR (GT35R_EF)
Stainless steel wool.
Old May 26, 2008 | 08:18 PM
welfarepc's Avatar
looks good tho.
maybe add more filters, why not you have space
old racers rule is have twice as much area for the vent as you have tube running to the catch can
Old May 28, 2008 | 07:13 PM
kommon_sense's Avatar
Default Re: FV-QR (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Stainless steel wool.</TD></TR></TABLE>
Be careful with any sort of steel wool. If a small piece breaks off, you can risk having it sucked into your engine depending on how you plumb up your lines.
You can use chain link
Old May 28, 2008 | 07:55 PM
Tony the Tiger's Avatar
Default Re: FV-QR
I actually used stainless steel windoe screen... Same stuff I used for most turbo "filter"...lol Works well, fine enough to cling oil and won't break into pieces like steel wool.
Old Jun 10, 2008 | 05:00 PM
kings**t's Avatar
Default Re: FV-QR (Tony the Tiger)
looks good
Old Jun 12, 2008 | 11:16 AM
Colorado S14's Avatar
Steel wool will do the job, I agree with your notion of not running steel wool in a can that is plumbed back into the oil pan.
Old Jun 12, 2008 | 04:04 PM
jazzpur's Avatar
Default Re: Custom catch almost done! Baffling? (Colorado S14)
the concept behind the baffling, other than deflection, is to add internal surface area thus allowing the oil vapor condense more readily. when i fab catch cans i usually use laps of preferated 0.040 alum. ive always been afraid to use steel wool
bergercurtis
Welding / Fabrication
May 1, 2016 01:01 PM
90Rexx
May 28, 2010 08:20 AM
kreatekustomz
May 21, 2010 09:11 PM
Plan B
Dec 23, 2002 04:35 AM
