215-50-16
Old May 23, 2008 | 03:54 AM
smackdown's Avatar
Default 215-50-16
anybody running 215-50-16 for 4th gen? are they to wide for 16x7 ? any input thanks.
Old May 23, 2008 | 06:41 AM
prelude_h22vtec's Avatar
they are def not too wide for 16x7. but they are kind of big IMO(about a half inch taller than stock). i like to keep it stock size outer diameter or smaller. they might rub on the inside of the fender, depending on what your offset is. but they should work.
Old May 23, 2008 | 07:32 PM
IrregularRice's Avatar
Default Re: 215-50-16 (smackdown)
Asuming you have 16x7 wheels to put the 215/50/16's on, it will work fine. you'll have about 1/4 inch of overhang on each side. which is handy is you dont want to scratch your wheels.
Old May 24, 2008 | 03:07 AM
smackdown's Avatar
Default Re: 215-50-16 (IrregularRice)
this where the 215s going into right now its 205-50-16 ssr type-c 16x7 offset is 42
Old May 24, 2008 | 03:35 AM
vinuneuro's Avatar
215 is a good width for a 7" wide wheel. I def wouldn't use 205.
Old May 24, 2008 | 01:21 PM
jmai86's Avatar
Default Re: 215-50-16 (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">I def wouldn't use 205.</TD></TR></TABLE>
What do you base this off? 205 is within recommended range for a 7" wheel.
205 is perfectly fine. I have 205/50/16 on a 16x7 wheel. Doesn't stretch, doesn't bulge. Handles great
I definitely wouldn't mess with the stock diameter. Keep it as close as possible, 215/50/16 is much too large for 4th gen preludes.
Old May 25, 2008 | 07:54 AM
vinuneuro's Avatar
Default Re: 215-50-16 (jmai86)
The reason is that widest possible tire for a given wheel width means more grip.
The gearing change from a 205 to 215 is only longer by 1.6%. If you really didn't like that everso marginally longer gearing, a 215/45 would get you 1.9% shorter.
OneSickJDMBB6
Apr 5, 2007 05:07 PM
OneSickJDMBB6
Mar 28, 2007 09:21 AM
Dr. Jay
Mar 28, 2005 04:47 PM
Nick H
May 10, 2002 04:20 PM
Double 06
Sep 27, 2001 05:21 PM
