if your smart?
Old May 22, 2008 | 09:41 PM
Spody02's Avatar
Default if your smart?
you might be able to tell me what this is
i broke the top piece, it was red and had a hose attached to it
your guess is as good as mine
the red box is where the piece came from
and the green arrow is there the top piece broke off and the hose was attached to a red nipple like thing
THANKS!
edit - also had a spring inside
Modified by Spody02 at 10:53 PM 5/22/2008
Modified by Spody02 at 11:07 AM 5/23/2008
Old May 22, 2008 | 10:20 PM
numberone's Avatar
Default Re: if your smart? (Spody02)
Idk what's its called, take the pic to the parts store and they will show you an exploded view of the parts and the names.
Old May 22, 2008 | 11:27 PM
VTEC_Du_Ma_Mai's Avatar
thats your pcv valve. should cost about 8 bucks from the auto store.
Old May 22, 2008 | 11:33 PM
adam081904's Avatar
Default Re: if your smart? (VTEC_Du_Ma_Mai)
yup pcv
Old May 23, 2008 | 07:24 PM
Electron00's Avatar
Default Re: if your smart? (adam081904)
like everyone said, it's the PCV valve...and if the piece broke off inside it, just remove it from the block and clean it out, and the parts should come out...just make sure it didn't fall into the block, meaning be careful when you're pulling it off and don't tilt it much to make it fall.
good luck!
Old May 23, 2008 | 08:12 PM
92integraVTECgsr's Avatar
Default Re: if your smart? (Electron00)
PCV Valve. I don't think anything can fall through.
Rob.
Jun 19, 2009 06:09 PM
pec pec
10
Feb 2, 2007 06:56 AM
Eagle16nam
Feb 26, 2006 01:26 PM
vipersr10
Jan 26, 2006 10:08 AM
spoon063
Honda Motorcycles
Oct 10, 2005 11:44 AM
