idle air control valve question
Old May 22, 2008 | 08:02 PM
cdfran's Avatar
Default idle air control valve question
i was just wondering if an iacv from an f22b will fit on an h22?
Old May 25, 2008 | 04:44 PM
prion's Avatar
Default Re: idle air control valve question (cdfran)
i had one for a while on mine and it was the same bolt pattern but had to have the hose hookups inverted. so you have to run longer coolant hoses and possibly extend the electical connector an inch or two. also, i had to tweak the throttle cable a bit so it wouldnt rub. but it functioned fine once installed.
ShatiaNichols
Jan 31, 2012 08:15 PM
lazyboy
Jan 22, 2008 04:05 AM
cbabyby
Apr 22, 2005 07:46 AM
