innovative mounts/hasport linkage.
Old May 22, 2008 | 07:49 PM
palisoc05's Avatar
Default innovative mounts/hasport linkage.
has anybody had any problems using Bseries(cable tranny) innovative mounts with the hasport shift linkage in there EF? just need want to confirm they work together before i decide to order anything. thanks
Old May 22, 2008 | 07:54 PM
90B16A2's Avatar
Default Re: innovative mounts/hasport linkage. (palisoc05)
No you shouldnt have any problems using those two items together.
Old May 22, 2008 | 09:44 PM
palisoc05's Avatar
Default Re: innovative mounts/hasport linkage. (90B16A2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90B16A2 &raquo;</TD></TR><TR><TD CLASS="quote">No you shouldnt have any problems using those two items together.</TD></TR></TABLE>
thanks for the reply. Anyone else have any experience?
Old May 22, 2008 | 09:53 PM
D16SiHatch's Avatar
I havent personally done this but i can tell you there won't be an issue. Regardless of who makes the mounts they all accomplish the same thing. They all are going to have the motor situated in the engine bay the same exact way regardless. whether its hasport or ebay mounts the motor isn't going to be in a different spot. there may be some slight variances among mounts but nothing appreciable enough to affect something like a shift linkage. that being said no matter what mounts you use the shift linkage is going to be unaffected.
Old May 23, 2008 | 09:34 AM
LowFlyin''s Avatar
Default Re: innovative mounts/hasport linkage. (D16SiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">I havent personally done this but i can tell you there won't be an issue. Regardless of who makes the mounts they all accomplish the same thing. They all are going to have the motor situated in the engine bay the same exact way regardless. whether its hasport or ebay mounts the motor isn't going to be in a different spot. there may be some slight variances among mounts but nothing appreciable enough to affect something like a shift linkage. that being said no matter what mounts you use the shift linkage is going to be unaffected. </TD></TR></TABLE>True, there is little chance that different mounts are going to affect the shift linkages, but it has been my experience that not all mounts position the engine in the same place. The Innovative mounts place the engine a little higher in the bay than the HAsport mounts. The car I bought came with HAsport mounts, B16A2, and a stock Si hood. After swapping the engine for a B16B (taller engine), I had to use a USDM SiR style hood and still had to trim some of the skeleton to close it.
Old May 24, 2008 | 07:42 AM
91blackEF's Avatar
Default Re: innovative mounts/hasport linkage. (LowFlyin')
you shouldent have any problems cause from what i hear they are almost the exact same thing made in the same factor just like skunk 2 and blox also same thing i jus think its downgraded materials and lacks the names everyone knows
sloed9si
May 21, 2009 03:04 PM
91EF_Si
Sep 27, 2007 07:09 PM
B16CRXT
Nov 27, 2004 12:21 PM
I-VTECRX
Jun 27, 2002 08:44 AM
