A Few CRX Si Questions
First and foremost, I did not find a straight answer for this question; When putting a Y8 head on an A6, how much is the timing off on the head and do you retard or advance it?
Secondly; What is the purpose for the small spring that attaches the T-belt tensionser to the block? It looks like it just hangs there...
Third and final; When I went through the options of hooking V-tec up, I found that a V-tec controller will not work due to not being able to control timing so it won't actuate properly. Is this true or is someone out there bluffing?
I apologize for the long thread I just want get some things straightened out.
Thanks in advance to all that adhere to this thread.
I don't know much about the specific timing part, but that spring is what actually provides the tension.
I wouldn't use a vtec controller. Your ecu will still use the same fuel and ignition maps for both high and low cams. Really not that good for performance. Convert to obd1 and run a vtec ecu. You'll be better off in the long run.
