ef9 with 99 ls swap problems?
Old May 22, 2008 | 07:27 PM
grodzef9's Avatar
Default ef9 with 99 ls swap problems?
i have a 99 ls swap on my ef9 and for some reason the crank pulley is rubbin the radius rod. i had a 93 ls swap before and this never happened. any suggestions?
Old May 23, 2008 | 05:23 AM
thevtecnician's Avatar
Default Re: ef9 with 99 ls swap problems? (grodzef9)
A few things you can do:
1)buy a ctr N1 single belt crank pulley
2)get the pulley you have shaved down to a single belt pulley
3) buy a set of traction bars
4)find an obd0 b series crank pulley
5) mount your radius rod on the bottom of the lower control arm as opposed to where it is now using longer bolts, spacers, and a grinder
92civiceg9gsr
13
Aug 6, 2011 05:13 PM
guy_from_nerk
12
Jun 30, 2008 04:00 PM
jaxx4k
May 20, 2006 08:50 PM
Biggspeed
Jan 18, 2002 01:00 AM
