Removing Door Panels
Old May 22, 2008 | 06:45 PM
JRZ88DX's Avatar
Default Removing Door Panels
so i'm thinking about repainting the Door Trim and i know hte best way to do it is by removing the door panels and takeing the trim off.
Does anyone have a diagram or info on how many bolts or screws it is and where they are so i don't break anything?
Old May 22, 2008 | 07:51 PM
90B16A2's Avatar
Default Re: Removing Door Panels (JRZ88DX)
There are two screws. Both very easy to locate. One is behind the inside handle, and the other is inside the little coin holder in the door. You must also remove the window crank. There is a U-clip between the crank and the door panel. That one is kind of a pain in the ****. I usually use a flat-blade screwdriver to fish it out. Other than those im pretty shure it just pops off after that.
Old May 22, 2008 | 09:01 PM
ha...tch's Avatar
theres also a screw on the top right of the panel where it meets the dash when closed. and one behind the speaker cover.
Old May 23, 2008 | 05:54 AM
tommycrx's Avatar
Default Re: Removing Door Panels (90B16A2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90B16A2 &raquo;</TD></TR><TR><TD CLASS="quote">There is a U-clip between the crank and the door panel. That one is kind of a pain in the ****. I usually use a flat-blade screwdriver to fish it out. Other than those im pretty shure it just pops off after that.</TD></TR></TABLE>
Look out!! If you do it this way, the clip shoots out like a motherf*er. What has worked out easier for me is to just wedge a thin towel in between the panel and the crank, and wiggle it back and forth until the clip pops out onto the towel. If you go with the screwdriver approach, what I would do is cover the entire area with a towel as you work it off to catch it. Otherwise, there's a good chance you'll be searching the area for that small clip, which isn't as fun as it sounds.
Modified by tommycrx at 9:59 AM 5/23/2008
Old May 23, 2008 | 08:38 AM
JRZ88DX's Avatar
Default Re: Removing Door Panels (tommycrx)
sweet, thanks guys
Old May 23, 2008 | 11:09 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Screw locations are indicated by the lines..
Old May 23, 2008 | 05:13 PM
JRZ88DX's Avatar
Default Re: Removing Door Panels (88DXCRX)
well damn!!
thats exactly what i wanted, thanks HT
Old May 26, 2008 | 10:51 AM
JRZ88DX's Avatar
ok, so i took off the long pieces of door trim, only snapping two white clips in the progress. How do i get the trim pieces off the quarter panels?
CWBETB
12
Jul 1, 2005 07:18 AM
raybord
Aug 11, 2004 04:59 PM
SPOONup
Apr 13, 2004 08:00 PM
JDM EJ1 95
Mar 25, 2004 03:13 PM
serious
Sep 6, 2002 04:40 PM
