Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Fix teh brakes take 62: Bushing recommendations for ECHC build-up please...
Old Jul 15, 2002 | 02:18 PM
Backmarker's Avatar
Default Fix the brakes take 62: Bushing recommendations for ECHC build-up please...
As folks who have been following my ongoing brake saga know, I need to replace the front lower control arm bushings on my EG Hybrid. I would appreciate folks thoughts / experiences on the subject. My priorities are performance, durability, and price - in that order. Car is track only. The contenders are:
MUGEN:
+ Hard Rubber
- Big dollars ($200+ for front set alone)...
Energy Suspension:
+ Cheap (in fact I have a set)
+ Polyeurethane
- Have a bad rep for binding, squeeking
OPM Motorsports
+ Delrin - very little flex
- Only make lower front inner bushing - I'd still need to source the rest
- Expensive ($105 for two bushings)
Progress Auto
+ Metal - very precise
- Cost
- Is this overkill, too bumpy?
Stock - Type R
? Anyone know if this would fit the front EG control arms?
Stock - EG
I am not very excited about using stock stuff if I have the chance to upgrade.
Please share your knowledge and experiences.
-Phillip
[Modified by ITR_Hybrid, 6:19 PM 7/15/2002]
Old Jul 15, 2002 | 06:49 PM
stevel's Avatar
Default Re: Fix the brakes take 62: Bushing recommendations for ECHC build-up please... (ITR_Hybrid)
Energy Suspension:
+ Polyeurethane
who cares about the squeaking, it's a track only car. I have them on my street car and it stiffened it up but I don't mind it. They're easy to find and cheap. I would go with an ES kit.
You can use the GSR lower control arms front and rear so you can put the GSR/Type R sway bars on. I ordered a GSR rear sway bar kit from http://www.hybridautomotive.com. The kit was about the same price as just LCA's would be from most junkyards that I found, they were hard to come by too.
s
[Modified by stevel, 10:49 PM 7/15/2002]
Old Jul 15, 2002 | 07:16 PM
Willard's Avatar
Energy Suspension:
+ Polyeurethane
Use marine quality l00b and you are set.
Willis
Old Jul 16, 2002 | 05:59 AM
B18CXr's Avatar
Stock R
trust me.
Old Jul 16, 2002 | 06:02 AM
krshultz's Avatar
I like the poly stuff fine. I think the people who say it binds mangled the install, didn't use the right grease, and/or are trying to sell you some pimpy delrin stuff.
If you make a decision based on squeaking I am never going to stop making fun of you
Old Jul 16, 2002 | 06:09 PM
Backmarker's Avatar
Default Re: Fix the brakes take 62: Bushing recommendations for ECHC build-up please... (krshultz)
Karl et al,
Forget the squeeking, I worry about the binding. I am leaning towards using the ES kit now as a quick fix and then maybe upgrading this winter when I have more time to test & play.
Anyone who thinks I care about squeeking hasn't heard my brake set-up recently - shims, what are those??
Besides - it's my driving you can make fun of. I am gonna OWN H5 next year. Of course, I 'll be running it H1....
Old Jul 16, 2002 | 07:27 PM
krshultz's Avatar
Ever since I re-lubed my ES bushings, things have been peachy. The binding I had was due to an incorrectly mounted rear sway.
Ideal? Probably not.
An improvement over busted-*** stock bushings? Absolutely.
Old Jul 16, 2002 | 08:32 PM
smokin rubber's Avatar
I like my prothane bushings and I only have the front ones installed, They squeak a little.
jdmsir4dr
20
Jul 13, 2010 05:51 PM
mattbatson
Suspension & Brakes
Mar 7, 2010 02:23 PM
an2ny888
Suspension & Brakes
May 8, 2006 05:31 PM
