Radio Install Question
Old May 22, 2008 | 09:58 AM
bopbop93030's Avatar
Default Radio Install Question
Car 95 Accord EX Sedan
I want to install an aftermarket radio and I want to use the OEM pocket, is it possible or do I have to get a new one to make it fit?
And yes I searched!
Thanks
Old May 22, 2008 | 10:21 AM
ZMan3000's Avatar
Default Re: Radio Install Question (bopbop93030)
You would definetly need a connector. You can splice the connector from the existing radio or you can buy one which will include the wire daigram . Best Buy and Walmart carries it. Depending on the aftermarket radio manufacturer and model you might have to get a kit. Just pull the existing radio out and check.
Old May 26, 2008 | 07:16 PM
slickster's Avatar
Default Re: Radio Install Question (ZMan3000)
I've found Crutchfield.com as the best source for aftermarket receivers that come with custom fit hardware and wire harness adapter for virtually any car model.
Old May 26, 2008 | 07:30 PM
TheMuffinMan's Avatar
He knows where you live!
The OEM "pocket" won't work well, someone ghetto rigged the one in mine by gluing it.
Just get a kit from like Best buy ~$25 and install it yourself
Old May 26, 2008 | 08:05 PM
tgdrums1990's Avatar
I think you will find that most after market kits have a pocket in the kit. Depending on the kits you get. Scoche kits are horrid. Really complicated and not well put together. Go with a metra kit and harness and you will thank yourself later. Crutchfeild is the way to go in order to get parts.
Old May 27, 2008 | 04:11 PM
slickster's Avatar
Default Re: Radio Install Question (tgdrums1990)
My Crutchfield kit came with a face plate that had the factory pocket on it. Installed great!
realred96
Audio / Security / Video
Jun 24, 2010 03:18 PM
reydio
13
Sep 11, 2006 04:45 PM
Thirty-Nine
Honda Fit
May 29, 2006 09:12 PM
SIMATIC
Mar 12, 2005 06:40 PM
RUBZERK
Sep 3, 2004 10:33 PM
