What is wrong? Why is it doing this?
Old May 22, 2008 | 08:25 AM
91greenbeast's Avatar
Default What is wrong? Why is it doing this?
I have a 91 civic si hatch with a jdm b16. I bought the car back from the same guy i sold it to and he told me theres a knot in the tire. I drove it and realized immediately thats theres not a a knot in the tire. The car was vibrating violently shaking the whole dash and all. I replaced the axles and wheel bearings all the way around. Still does it but not as bad. It shakes on the passenger side when accelerating and hit small dips and also when i turn to the right. Ball joints are also new. Can someone help me out?
Old May 22, 2008 | 08:42 AM
Bjorn20's Avatar
Default Re: What is wrong? Why is it doing this? (91greenbeast)
how are the tie rods? Try taking it to a shop and have that tire balanced and see if the rim is bent/warped and check for tire separation.
Were the bearings making noise at all before you decided to replace them? Make sure the front end is tight as well, any loose suspension/steering components will cause the symptom you described.
Old May 22, 2008 | 08:51 AM
grog's Avatar
how are the motor mounts? is anything bent?
Default Re: What is wrong? Why is it doing this? (Bjorn20)
I put a different set of wheels on it and checked everything on it. Still does the same thing. I took it to the shop yesterday and had everything check and everythings ok. They put new wheel bearings in and they told me one of them got hot and welded itself in. How the car was driving? No clue
Old May 22, 2008 | 11:15 AM
wheel bearings are fine . only does the vibration on acceleration only. when you turn to the right makes noise. im putting a new axle in 91 integra non abs. when i got the car it was coming from both sides. i replaced both axles cause they was wrong. now only doing it from the passenger side. ys1 tranny stock si hubs did take the ring out when i did the swap tie rods are fine motor mounts are tight.
Old May 22, 2008 | 01:57 PM
jdmboyef9's Avatar
Do you know for 100% that the half-shaft is a YS-1? If you have a Y1 half-shaft then the axles would be slightly too long. I had this problem before and it caused the tire to bounce and almost hop driving down the road...
Also if it has a camber kit check to make sure all of the bolts are tight.
Old May 22, 2008 | 03:33 PM
sirtef9's Avatar
Default Re: What is wrong? Why is it doing this? (jdmboyef9)
I had a half shaft go out and it vibrated when I hit a bump, take it off and check for excessive play in the bearring.
Old May 22, 2008 | 05:01 PM
mackadocious's Avatar
* B A N N E D *
its prolly piece of rust that fell inside the rotor causing it to be cricket and make the car shake ..when stoping or ...or prolly motor over flooded with oil leaks
Old May 22, 2008 | 05:51 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: What is wrong? Why is it doing this? (mackadocious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mackadocious &raquo;</TD></TR><TR><TD CLASS="quote">its prolly piece of rust that fell inside the rotor causing it to be cricket and make the car shake ..when stoping or ...or prolly motor over flooded with oil leaks </TD></TR></TABLE>
Whaaaaaaaat?
OP, try to determine the exact halfshaft you have.
Old May 22, 2008 | 07:10 PM
Ahks's Avatar
genius tbh...
Old May 23, 2008 | 02:38 AM
Default Re: What is wrong? Why is it doing this? (Ahks)
so more than likely its the half shaft?
Old May 23, 2008 | 07:53 AM
jdmboyef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91greenbeast &raquo;</TD></TR><TR><TD CLASS="quote">so more than likely its the half shaft?</TD></TR></TABLE>
It is a possiblity so check it out before you go and replace it....
Old May 23, 2008 | 06:29 PM
what axles do i need for the xsi trany? the civic has the stock si half shaft
Old May 24, 2008 | 09:45 PM
i bought a complete jdm b16 swap for a 91 si. I sold the car to a dumbshit. I have recently purchased the vehicle back. He put a ys1 tranny in it. What half shaft would come with a complete jdm b16 swap and what axles would go with a jdm b16 half shaft with a ys1 tranny. Thank you for all your help in my time of need.
Old May 27, 2008 | 11:34 AM
jdmboyef9's Avatar
Some of the 89-91 B16A's came with the Y1 tranny which means that no usdm axles will work with that half shaft. If you swap in the ys1 half shaft then you can use any 90-93 integra axles abs or non, it does not matter.
If he changed the tranny and kept the old half shaft than that would be the problem if the old one was in fact a y1 half shaft.
The stock si never came with a half shaft.
SedanLYF
Oct 29, 2010 06:36 PM
Supremee
Mar 14, 2008 08:46 AM
LSegHatchy
Oct 24, 2005 06:51 PM
trooper0641
Oct 28, 2003 07:55 PM
Mr Samson
Nov 5, 2002 07:38 PM
