Just a poll (new engine vs. rebuild head)
The easy thing would be to rebuild the head. As long as you are sure there is no damage to the pistons or block.
Another thing to look at is the condition of the block and how it was running before the valves where bent. How many miles on it. It may be worth your while to replace the motor if it is a high mileage oil burner.
You can always get a used engine. Get a Japanese used engine. There are lots of place that import honda engine from Japan. I got mine from Patterson, NJ for $650. The engine is still running good Thank God and there is no oil burning so far with 25k on it.
If you are going to go with the rebuilt option, you migh as well as go all out and rebuilt the engine replacing all the major components - head gasket, timing belt etc. depending on the mileage. You don't want to put a new trans after going through an engine rebuilt.
If you have a manual trans - you should consider replacing your clutch depending on the mileage and which option you go with.
Best of luck.
Best of luck.
It is a real pain in the butt to remove the head on that 83 Accord, and with ALL THOSE MILES on the engine you should rebuild the bottom end.
$650 for an 83 accord engine would be a great deal.
Sorry i should have put more information in the first post.
90 Accord with 160,000 miles
Manual transmission, (the clutch pedal has to go almost to the floor board for it the disengage the transmission, but shifts fine.
Which Japanese replacement engine company is the best to deal with?
Thanks
Thanks
I didn't break the timing belt (not saying someone else did. I bought it this way), but I ran a compression test because it was running rough. 1=180, 2=170, 3=180, 4=0.
I looked inside the cylinder from the spark plug hole and everything looked fine, so that is the only thing I can think of.
This is were I got my used engine from about 2 years ago.
Japanese Engine
Rate It and Win
60 Spruce Street, Paterson, NJ 07501
map | driving directions
Cell Phone | Email
phone: (973) 881-8158
Current Phone: [close]
(973) 881-8158
Change Phone to:
Current URL [close]
Change URL to
Japanese Engine
Rate It and Win
Cell Phone | Email
(973) 881-8158
Change Phone to:
Current URL [close]
Change URL to
nsiders09
11
Mar 3, 2016 03:01 PM
crashtest Sonny
Aug 9, 2003 02:53 PM
sauceman
Feb 8, 2003 05:34 AM
