help!! trying to figure wats the promblem of my handling
Old May 21, 2008 | 10:02 PM
w1ckedboy504's Avatar
Default help!! trying to figure wats the promblem of my handling
im trying to figure out wats wrong with my 96 civic hatch i jus recently drop some tein spring on there and it got really bouncy and when i drive on the highway when i hit about 80 and hit a bump my car start moving to aside like i cant control it i thought it was my alignment but its not is it because of the springs??
Old May 21, 2008 | 10:30 PM
supersteven's Avatar
What kind of shocks are you running?
Old May 22, 2008 | 10:50 AM
i got tein s tech spring and tokico blue shocks and is any1 tein s tech spring bouncy?? mine is really bouncy worser then coilover
Old May 22, 2008 | 11:24 AM
NOFX's Avatar
H-T White Ops
I have Tein S-Techs and they ride very similar to stock springs. My car never tosses back and forth when I hit bumps or anything like that.
Old May 22, 2008 | 12:06 PM
Dirty Octopus's Avatar
Default Re: help!! trying to figure wats the promblem of my handling (w1ckedboy504)
a bad alignment can cause a lot of problems. dont be too quick to rule out your alignment. i say get one done to be sure
Old May 22, 2008 | 12:57 PM
Malakai's Avatar
Why did u start another thread?
https://honda-tech.com/zerothread/2304482
I'll say again, did u cut your bump stops like your supposed to when u put the springs on?
Old May 22, 2008 | 03:27 PM
yea i jus recently got a new alignment but thats not the promblem it still do the same thing
Old May 22, 2008 | 03:31 PM
jdeemseerx's Avatar
Default Re: (w1ckedboy504)
If the symtpom your experiencing is bump steer (hitting a bump and the steering wheel jerks to one side) it could very well be your tie rods. If you got your alignment done and that is the problem to the shop.. jack your car up and put the stand on the control arm so it is preloaded..(straight) try to move your inner/outer tie rods with your hand. If they have play in them, replace as necessary. This usually happens when you drop, now the suspension is at a different angle so you feel it more.
Old May 26, 2008 | 10:35 AM
so u think its the cv joint axle?? that causing the promblem? because my cv joint axle u can hear it grind when i turn
accordbeliever
Apr 5, 2013 01:29 PM
w1ckedboy504
May 24, 2008 07:55 PM
w1ckedboy504
May 22, 2008 11:16 AM
m0nk
Suspension & Brakes
Mar 14, 2005 08:04 PM
XoUnKoWnXo
14
Jul 30, 2004 01:32 PM
