d15 Eg to b18 Eg swap...what shift linkage???????????
Old May 21, 2008 | 08:56 PM
the.hamburglar's Avatar
Default d15 Eg to b18 Eg swap...what shift linkage???????????
ummm i kinda feel like a retard asking this question. i searched through 2 pages and everyone seems to think 94-01 integra shift linkage works...well it didnt for me tonight. does a 92-95 civic coupe have the same linkage as a 92-95 civic hatch? the stabilizer bar seems to fit but there is something messed up going into gear, or almost going into gear. it doesnt quite click in and 2,4, R dont even engauge. what should i change?
Old May 21, 2008 | 09:34 PM
superfast666's Avatar
Default Re: d15 Eg to b18 Eg swap...what shift linkage??????????? (the.hamburglar)
it works for everyone else your shift linkage could be bent
Old May 21, 2008 | 09:35 PM
sleeperrex's Avatar
ummm 94-01 should work , it did for me in my eg, you sure u got the right linkage? you put in the shift pin right? and your bushings good?
Old May 22, 2008 | 04:57 PM
Default Re: d15 Eg to b18 Eg swap...what shift linkage??????????? (sleeperrex)
yes and yes! what doesnt make sense to me is that it goes into gears 1, 3, 5 but not 2, 4 and R.
Old May 22, 2008 | 05:03 PM
d15nonvtec's Avatar
bent linkage
same thing happened to me take it back out and "tweak" it a little
Old May 22, 2008 | 05:05 PM
Default Re: d15 Eg to b18 Eg swap...what shift linkage??????????? (d15nonvtec)
tweak it? i dont even know what way. i just remembered something else...going from side to side in neutral...there is alot of play. the shift **** almost hits the seat.
Old May 22, 2008 | 05:56 PM
iluvmy2000civicex's Avatar
Sounds like its bent pretty bad. Either try a different one or MAKE that one work.
flipldls
Transmission & Drivetrain
Oct 22, 2009 12:33 PM
selfmade209
May 11, 2009 09:59 PM
tfeagley
Mar 15, 2009 11:18 AM
jin4g63
Sep 7, 2007 01:29 PM
THEDirtyDseriesWOOT
Mar 13, 2007 08:20 PM
