PCV Valve Idle Issue
Old May 21, 2008 | 07:31 PM
BiG_DeE's Avatar
Default PCV Valve Idle Issue
So ive been dealing with some idle issues, and figured out that i was using wrong gasket on tb, because its a d16z6 IM with a LS TB so now i still have a slight idle issue and ive keyed it down to my PCV valve on top of the Valve Cover, If i cover the valve, it takes a second but it starts to idle normaly but the alternator belt makes a loud screeching sound.. any ideas??
Old May 22, 2008 | 05:52 AM
BiG_DeE's Avatar
Default Re: PCV Valve Idle Issue (BiG_DeE)
anyone have any ideas?
Old May 22, 2008 | 07:11 AM
wonder squirrel's Avatar
I assume when you plug the PCV the idle drops down a little bit right? Check your belt for glazing or wear.
Pull the PCV off and shake it, if it rattles its good, if not, replace it. Report back and goodluck!
turbo_d16
Jun 18, 2011 10:22 AM
pro547
Mar 12, 2005 12:54 PM
honda8882
May 6, 2003 03:32 AM
caliquick_teg
Jan 23, 2003 05:34 AM
Accorden
Mar 30, 2002 08:03 PM
