Springs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 »</TD></TR><TR><TD CLASS="quote">PRO TIP: Save up and do it right the first time, and you will save money down the road. (coilovers)
i think coilovers are overkill if people don't plan on autoxing or road racing.
</TD></TR></TABLE>i think coilovers are overkill if people don't plan on autoxing or road racing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ep3some »</TD></TR><TR><TD CLASS="quote">If you go with lowering springs, WhiteOnRice is correct; match it up with a good shortr shock. You can use your stock ones for a little while but they won't last long.</TD></TR></TABLE>
all the above posts are correct... as from my experience.
mine came with "Nuesprings" Yellow- Racing series- 2" drop...
i LOVE it!
its very solid/stiff... no wheel rub (even with tall snow tires!)
but what they said about oem shocks is true,
mine and many others have "blown-out"/leaked after only 20,000 miles after being lowered.
i've looked into shocks, with koni's and tokico's as a viable option...
(but if i were you, i'd go with adjustable coil-overs and be done with it! then you're not held back)
when lowering with springs, expect a steering creak, get a camber kit and new shocks, then a good alignment!
good luck
i LOVE it!
good luck
springs will be fine. I have H&R springs, as well as skunk2 springs for my ep3.. They both ride better than stock. I Highly suggest upgrading your shocks though. Mine feels like I hit a [freak]ing goat everytime i go over a bump
Exploder39
May 18, 2007 09:08 AM
