car wont start
was drivin and it shut off on me ...cel is on constant wen at acc.....wont throw a code....main relay clicks once.....power to dizzy but no spark......no power to injectors...fuel has been on constant power for about a yr i 4get wat made me do it...fuel reaches fuel rail juz wont release....helppp
you check your fuses? check grounds?
when the key is in the acc position, the CEL will come on, that doesn't mean anything. If it's on while driving, you need to pull the codes.
as mention by >>chimmike<< did you check your fuses and grounds.!?!? or anything.?!??! when something goes wrong, you must start and always go back to the basics/plain and simple first...
"fuel wont release" so what? Your plugs are not igniting aka the car is not starting so the fuel should just reach the rail. It doesn't sound like a fuel problem.
It absolutely sounds like a ground wire and/or a coil problem.
luckystryx
Aug 29, 2018 06:15 PM
SoCal07Si
12
Apr 25, 2011 10:54 AM
fasst
Engine Management and Tuning
Aug 5, 2009 06:36 AM
silvervtecrx
Oct 10, 2004 07:30 PM
