FS: Out of the game. B16 all motor parts. skunk2 CTR pistons, ACT, DC5R. Pic intensive 56k, have s
Old May 21, 2008 | 01:53 PM
Carbonyl's Avatar
Default FS: Out of the game. B16 all motor parts. skunk2 CTR pistons, ACT, DC5R. Pic intensive 56k, have s
All parts are for a b16, but they may fit other B-series engines. If you buy it all, excluding the miscellaneous parts I will sell it all for 2100. If you were planning to do a swap, this is a better way to spend your money and build a beast. All you have to do is machine the block and the head, buy good valve springs retainers and cam gears, and you are looking at a 200 WHP monster at least. At least that was my plans until my car got stolen. Prices are pretty firm but there is wiggle room on some items. Does not include shipping and if you use paypal, you will need to add 3.5%.
CTR Pistons w/ Rods -300 - .25 overbore Also comes with ARP rod bolts and they are shotpeen'd. Machine work alone was already 200. Also comes with piston rings
Skunk2 Cams -400 - Brand new, never used.
ARP Headstuds -100 - Brand new for b16
Type R oil pump -100 - Brand new from Acura dealer
skunk2 intake manifold -200 - Brand new
DC header -200 - Basically Brand new, test fitted
ACT 4 puck clutch -250 - Brand new
ACT XACT Steetlite -150 - Brand new
p28/ S100/harness -230 - Not Brand new, but its still a nice item. Comes with obd2b to obd1 harness
B16 block/cranks -100 - Comes with two blocks. One block apparently has a knick on the cylinder wall after it was bored out .25 for the pistons. Both have cranks and one is complete. One of them has a balanced crankshaft as well. The one showing the crankshaft is balanced.
Prelude injectors -60 From a 97-01 Prelude. I think 290cc, perfect for all motor applications
b16 head -150- Has scarring on one side where the camshafts sit. About 100 to fix at the machine shop. Basically complete minus cams and distributor
ACL bearings -100 - Brand new
Gasket set -50 - Missing intake manifold gasket, but otherwise complete, may be missing o-rings for injectors as well
waterpump/timing belt -50 - Brand new
Walbro fuel pump -75 - Brand new
I also have a b20 head and a pretty rusted LS block if anybody is interested in that
Here are the pictures
All parts are for 99-00 Civic
Miscellaneous parts
DC5R steering wheel -325
EP3 Steering wheel -50
99-00 Civic Si Radio -50
Integra LS spoiler -25
Civic Axle back -25 - Has matrix muffler welded on to it
CF hood messed up -50
Xenon Rear lip -50 - Covers entire bumper
Modified by Carbonyl at 4:46 PM 5/21/2008
Old May 21, 2008 | 03:31 PM
Project-Honda's Avatar
Default Re: FS: Out of the game. B16 all motor parts. skunk2 CTR pistons, ACT, DC5R. Pic intensive 56k, ha
Old May 21, 2008 | 03:46 PM
Carbonyl's Avatar
thanks for the bump
Old May 21, 2008 | 07:12 PM
Carbonyl's Avatar
up
Old May 21, 2008 | 07:16 PM
Carbonyl's Avatar
up
Old May 22, 2008 | 12:23 PM
Carbonyl's Avatar
bump
Old May 22, 2008 | 12:34 PM
gunmetal si's Avatar
you willing to ship the head to stl,mo?
Old May 22, 2008 | 12:41 PM
hai_tech's Avatar
well the clucth work for b16 cable tranny?
Old May 22, 2008 | 10:56 PM
Carbonyl's Avatar
the head is pending, and i dont even think its worth shipping since it will cost like 50 to ship, and then another 100 to machine, when you can probably find a good local head for about the same price. About the cable tranny I am not sure, but I think it might work since I have not seen different clutches for different types of trannies, but I could be wrong.
Old May 23, 2008 | 01:34 PM
Carbonyl's Avatar
up
Old May 23, 2008 | 02:06 PM
crip's Avatar
how much to ship those blocks to Tallhassee Florida 32327
Old May 23, 2008 | 05:56 PM
Carbonyl's Avatar
Default Re: (crip)
if you want those blocks, they probably weight around 20-30 lbs with the crank so it would not be worth it to pay 100+shipping on them when you can probably find one local for 150ish, unless its the fact thats its two. But it will cost about 35 per block to ship, which would make it 170 ish shipped + paypal fees
Old May 25, 2008 | 06:13 PM
Carbonyl's Avatar
up again
Old Dec 13, 2008 | 06:38 PM
flip1405's Avatar
want to know a couple of things about the ep3 steering wheel?? airbag or no airbag? let me know.
Old Dec 13, 2008 | 06:48 PM
XKINGX's Avatar
bump
Old Dec 13, 2008 | 07:24 PM
top end tuner's Avatar
need pics of the gasket set and the walbro fuel pump please
Old Dec 15, 2008 | 06:12 PM
flip1405's Avatar
Still waiting for info on the ep3 steering wheel.
DoNDoNJJJ
Jan 4, 2011 05:03 PM
hifi_civic
Sep 12, 2005 09:34 PM
mraudio13
Sep 11, 2003 11:33 AM
