Need Wiring Help With B16 Swap ASAP
Old May 21, 2008 | 10:33 AM
CTR_B's Avatar
Default Need Wiring Help With B16 Swap ASAP
Ok so Im attempting to swap a B16A into my buddies Ef for him. I have done numerous swaps in EG's Before but never into an Ef. My Problem is when I traced back the wiring harness to make sure it was right I found that there was an extra small round plug going to the chassis the the chassis harness doesnt have with 3 yelow 2 greens and a red and white. There was also a smaller 2pin plug with a blk with yellow stripe and a blk with white stripe. Another thing that is missing on the engine harness that IS on the chassis harness is the flat 8pin plug.
I traced threw both harness and it seems all the wires are there just in different plugs? Am I correct.. Do I need to chop and splice to make this work?
I will take any answer at this point.. Please help
Old May 21, 2008 | 11:02 AM
CTR_B's Avatar
Default Re: Need Wiring Help With B16 Swap ASAP (CTR_B)
I've tried search but with no luck, Could some one please help me with this.
Old May 21, 2008 | 11:55 AM
gursh d's Avatar
pics would definately help.
Old May 21, 2008 | 12:10 PM
jlicrx's Avatar
<U>rule</U> <U>number</U> <U>1</U> <U>for</U> <U>engine</U> <U>swaps</U> - <U>always</U> use the engine harness that came in the car that the new engine is going into and make any necessary wiring changes to that harness - engine harnesses are not interchangeable between different models and sometimes not even interchangeable between different years of the same model
Old May 21, 2008 | 12:27 PM
CTR_B's Avatar
Default Re: Need Wiring Help With B16 Swap ASAP (jlicrx)
I will Get some pics up asap for you guys
Also the engine harness that was in the car is hacked due to the P.O trying to convert his OBD0 Harness to an 0BD1 so that he could install OBD1 D15 (waste IMO) So reusing the harness that came is out of the question.
Nate Boslet
Apr 17, 2017 05:16 AM
CTR_B
Jun 18, 2008 04:25 PM
csubucky19
Jul 27, 2007 09:46 PM
bbrian
Oct 22, 2005 11:18 PM
