need help getting the name of a part!!
Old May 21, 2008 | 09:01 AM
aeenox's Avatar
Default need help getting the name of a part!!
What is the sensor on the throttle body called? Because i am swapping out a 91 b18a into a 93 shell and i already switch the wiring harnest from obd0 to 0bd1 but the plug on the throttlebody sensor is diffrent and the fuel injectors too. So im going to to just buy new fuel injectors and a new sensor but i dont know the name of the sensor. Can anyone help me out
Old May 21, 2008 | 05:44 PM
aeenox's Avatar
Default Re: need help getting the name of a part!! (aeenox)
damn no one knows the name?????
Old May 21, 2008 | 07:55 PM
g2daturbo's Avatar
throttle postion sensor.... they are the same between 90-93 integra.. take a pic so we know what ur talking about.... injectors are obd0 90-91 and obd1 92-93 can be found used pretty easily..gonna be very costly new... i have a nice set if ur interested!
Old May 22, 2008 | 08:50 AM
aeenox's Avatar
well im goin to go take pictures today
Old May 22, 2008 | 09:21 AM
jimmyrab's Avatar
Default Re: (aeenox)
not 100% about older integras but im pretty sure map sensor is also on the throttle body
Old May 22, 2008 | 07:33 PM
aeenox's Avatar
well i found out wat was goin on today with the wiring wat happend was that the dumb *** "mechanic" that was doin the swap for me got and automatic wiring harnest insted of a manual harnest ..... :/
Old May 22, 2008 | 07:57 PM
aeenox's Avatar
would a 94 obd1 wiring harnest work on a 93 ls?? or a 93 dx obd1 work?
Modified by aeenox at 4:13 PM 5/23/2008
Old May 23, 2008 | 03:13 PM
aeenox's Avatar
help anyone?
Old May 23, 2008 | 05:49 PM
inspiration's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeenox &raquo;</TD></TR><TR><TD CLASS="quote">What is the sensor on the throttle body called? Because i am swapping out a 91 b18a into a 93 shell and i already switch the wiring harnest from obd0 to 0bd1 but the plug on the throttlebody sensor is diffrent and the fuel injectors too. So im going to to just buy new fuel injectors and a new sensor but i dont know the name of the sensor. Can anyone help me out </TD></TR></TABLE>
TPS is on the throttle body and the MAP sensor is on the firewall. Since you are using a OBD-0 B18A and swapping it into a OBD-1 chassis. You either need the injector harness from the old engine wiring harness or get OBD-1 fuel injector harness.
Old May 23, 2008 | 06:50 PM
PaChiLa Leader's Avatar
Default Re: need help getting the name of a part!! (inspiration)
TPS
cryingsuns
Mar 20, 2011 01:13 PM
Cole89ef
Mar 9, 2009 05:50 AM
sivik2nr
Aug 24, 2002 07:02 AM
