ChanpLSinteg's build...what do y'all think?
Old May 21, 2008 | 06:59 AM
champLSinteg's Avatar
Default ChanpLSinteg's build...what do y'all think?
What’s up guys! I regularly see people post there set ups here so I figured why not post mine too! This is my third build with the same turbo. My first was with a stock block lsvtec making 280whp on the 2.25in exhaust for almost a year until I decided to go with a 3in exhaust without doing a retune. That ended in blown ringlands. Soon after I picked up a RS sleeved type r block. I built it using 81.5mm 9.8:1 wisecos and eagle rods. It cracked a piston due to overheating and a .0025in pw clearance. I should have gone with my gut to go with a larger clearance but I didn’t. This time around I went with .004in to allow some room for error, just in case. All built by me and tuned by Dave at DNR performance . This has been a nightmare for my fiancee by she has supported me anyways Here’s my set up…
Head:
Stock port B16 head
Buddy Club P1 springs and retainers
ITR intake cam / GSR exhaust
VictorX intake manifold
Stock LS throttle body
Block:
83mm RS sleeved B18C5
9.8:1 CP pistons
Eagle Rods w/ 3/8 bolts
ARP head studs
Polished and balanced LS crank
ITR oil pump / water pump and OEM gaskets
Honda Bearings
Transmission:
GSR with OBX lsd
Competition Stage 5 Clutch
Turbo:
Full-Race ramhorn
t3/t4 60trim w/.63ar
3in downpipe
3in exhaust
44mm Tial wastegate
50mm Tial BOV
2.5in intercooler piping
Ebay intercooler
Fuel:
Precision 1000cc injectors
AEM fuel rail
Aeromotive A1000 FPR
Walbro 255
Electronics/Tuning:
Hondata S300
PLX M300 wideband
Greddy Profec B Boost Controller
MSD 6AL
Here are some pics...
and this is the outcome...
Modified by champLSinteg at 9:51 AM 7/15/2008
Old May 21, 2008 | 07:06 AM
chimmike's Avatar
Default Re: My build...what do y'all think? (champLSinteg)
Sweet! I like your choice on the 9.8:1 pistons. Makes for lively driving without boost.
Old May 21, 2008 | 08:04 AM
Default Re: My build...what do y'all think? (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">Sweet! I like your choice on the 9.8:1 pistons. Makes for lively driving without boost.
My motor is loving this compression and so am I.
Old May 21, 2008 | 08:20 AM
raiden571's Avatar
did you do a compression calculator? i think you might be a lil higher.
Old May 21, 2008 | 08:30 AM
hatchkid91's Avatar
nice
Old May 21, 2008 | 09:28 AM
Default Re: (twinturbosupra123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 &raquo;</TD></TR><TR><TD CLASS="quote">did you do a compression calculator? i think you might be a lil higher.</TD></TR></TABLE>
I actually get lower numbers with the calculators. I called CP and had them calculate it and they said it was 9.7 with unsurfaced head and estimated it around 10:1 with the head is milled .012. I didnt have the combustion chamber volume so he said 10:1 is probably tops.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinturbosupra123 &raquo;</TD></TR><TR><TD CLASS="quote">nice</TD></TR></TABLE>
thanks!
Old May 21, 2008 | 10:16 AM
Supacharge's Avatar
Default Re: (champLSinteg)
nice set up. very clean!
Old May 21, 2008 | 10:47 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Supacharge)
nice fun number
Old May 21, 2008 | 02:01 PM
Default Re: (HybridcivicLS-T)
I need to get an alignment now. It is all over the place!
Old May 26, 2008 | 05:43 AM
g3teg97's Avatar
Nice, although I was expecting it to be over 300wtq when I saw you at 424whp. Still, quality parts and sweet overall car!
Old May 26, 2008 | 10:22 AM
RC000E's Avatar
Default Re: (g3teg97)
Nice car man. I'm a little confused over the "this has been a nightmare for my fiancee" No build should be that much drama to create a nightmare....what made it so bad?
Old May 26, 2008 | 05:32 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Nice car man. I'm a little confused over the "this has been a nightmare for my fiancee" No build should be that much drama to create a nightmare....what made it so bad?</TD></TR></TABLE>
well he is on his 3rd motor, i cant imagine anyone calling that "fun"
Old May 26, 2008 | 07:56 PM
JdMhEaD's Avatar
My fiance hates my builds.....
Old May 26, 2008 | 08:10 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (JdMhEaD)
wait till fiance turns into wife!!!!!!!!!!
Old May 27, 2008 | 04:13 AM
jmm96gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">wait till fiance turns into wife!!!!!!!!!! </TD></TR></TABLE>
I always remind my wife that aleast I'm home and working in the garage and not out at strip clubs and bars. BTW, OP nice build.
Old May 27, 2008 | 06:54 AM
Default Re: (jmm96gsr)
I spent most of my time in the garage or online whenever I was not at work, money, driving a "highly modified" car on california streets, the garage is a mess! LOL, etc.
Now that I am done, for now, I have been spending more time with her.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmm96gsr &raquo;</TD></TR><TR><TD CLASS="quote">
I always remind my wife that aleast I'm home and working in the garage and not out at strip clubs and bars. BTW, OP nice build. </TD></TR></TABLE>
I remind her of this all the time!
Old May 27, 2008 | 07:00 AM
Thanks for the props!
By the way, the little dip in the top end was caused by a little boost drop. it went from 15psi to 14ish for a moment and recovered.
Now I need some more seat time.
Old May 27, 2008 | 07:34 AM
when do you get full boost by? it looks a little before 5k
Old May 27, 2008 | 07:47 AM
Default Re: (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">when do you get full boost by? it looks a little before 5k</TD></TR></TABLE>
I have to look at the datalogs but I think it was around 4700ish. I rev to 9200 to its quite a powerband!
Old May 27, 2008 | 08:33 PM
VEGAS_CTR's Avatar
sorta similar to my new setup,did it see the track yet?
Old May 27, 2008 | 11:20 PM
Default Re: (VEGAS_CTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VEGAS_CTR &raquo;</TD></TR><TR><TD CLASS="quote"> sorta similar to my new setup,did it see the track yet?</TD></TR></TABLE>
It will this Saturday at CMI. I've done 12.1 with a shitty 60ft. I need to get an alignment, lower the tire pressure and get more seat time
Old May 27, 2008 | 11:34 PM
krazyhmongboi's Avatar
&lt;-----jealous now
Old May 28, 2008 | 03:39 AM
DfwBB6's Avatar
Default Re: (krazyhmongboi)
nice build
Old May 28, 2008 | 06:31 AM
boostedeg302's Avatar
Default Re: (DfwBB6)
solid build. How's that LSD been holding up for you?
Old May 29, 2008 | 07:01 AM
Default Re: (boostedeg302)
The LSD is holding up pretty good. I have not had any issues with it at all.
