What pad/rotor setup are you guys running?
Old May 21, 2008 | 06:30 AM
Duck Sauce's Avatar
Default What brake pad/rotor setup are you guys running?
I got some warped rotors that are in need of replacement and I will change the pads at the same time. Just wondering what kind of brake setups you guys are running for daily driver/occasional spirited driving use?
I was thinking Brembo blanks and Hawk HPS pads.
Where's a good place to order brake parts from?
Old May 21, 2008 | 06:39 AM
98vtec's Avatar
moderator emeritus
Default Re: What brake pad/rotor setup are you guys running? (Duck Sauce)
OE honda pads, OE honda rotors
Old May 21, 2008 | 01:41 PM
md23vtec's Avatar
Default Re: What brake pad/rotor setup are you guys running? (98vtec)
OEM pads PowerSlot rotors all the way around on both of my preludes
Old May 21, 2008 | 01:45 PM
Scheizty's Avatar
Default Re: What brake pad/rotor setup are you guys running? (md23vtec)
Powerslot rotors and hawk pads. Been treating me great on my 99.
Old May 21, 2008 | 03:41 PM
ludiferino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duck Sauce &raquo;</TD></TR><TR><TD CLASS="quote">I got some warped rotors that are in need of replacement and I will change the pads at the same time. Just wondering what kind of brake setups you guys are running for daily driver/occasional spirited driving use?
Where's a good place to order brake parts from? </TD></TR></TABLE>
Are you certain they are warped? http://www.stoptech.com/tech_i...shtml
I liked the axxis/pbr ultimate pads; good for auto-x, good initial bite, lots of dust. I also liked the cobalt gt-sports, but those were the older pad material.
Old May 21, 2008 | 04:02 PM
G2IntegraGS's Avatar
Hawk HPS with autozone blanks. I gotta say I could use some mor stopping power when Im at the strip.
Old May 21, 2008 | 05:00 PM
SikB's Avatar
I use carbotech oe blanks and their bobcat pads. I could have spent a couple grand on large rotors and multi piston calipers but I chose to go this route because it was far better performance for $100 pads. A little dusty though.
Old May 21, 2008 | 05:08 PM
Saosinx's Avatar
Default Re: What brake pad/rotor setup are you guys running? (SikB)
i'm surprised there hasn't been people screaming brembo blanks in this thread...
Old May 21, 2008 | 05:40 PM
Giant_Bean's Avatar
Default Re: What brake pad/rotor setup are you guys running? (Saosinx)
I like my Brembo blanks and my PBR pads, I also get stuff through where I work, so it's all cheap.
Old May 21, 2008 | 07:09 PM
ludecz's Avatar
Default Re: What brake pad/rotor setup are you guys running? (Giant_Bean)
So far I'm using autozone rotors with hawk HP+ for HSAX they bite good even when cold but dust alot.
Old May 21, 2008 | 09:53 PM
no1knows908's Avatar
Default Re: What brake pad/rotor setup are you guys running? (ludecz)
I also noticed that my AutoZone rotors tend to build up a lot more rust than my OEM ones did...
Old May 21, 2008 | 10:54 PM
ejprimo's Avatar
Default Re: What brake pad/rotor setup are you guys running? (no1knows908)
Duralast pads and valuecraft rotors on my gf's 97 prelude.
Old May 22, 2008 | 07:02 AM
ImPuLsIvE's Avatar
Front = Wilwood 4-pot calipers, 13.25" 2-peice drilled rotors & Hawk HPS pads.
Rear = Oem Spec cross-drilled rotors & Semi Metallic CF pads.
Wilwood SS Lines all around.
Old May 22, 2008 | 03:05 PM
aquito's Avatar
93 si vtec: oem pads and oem rotors
Old May 22, 2008 | 09:53 PM
bb6_00's Avatar
anyone running EBC brake pads?
Old May 22, 2008 | 10:35 PM
93sivtec's Avatar
Default Re: (bb6_00)
I have powerslot rotors paired with aem pads in the front and oem drilled and slotted rears w the same pads.....ss brake lines all in all great bite,low noise and no fade,even at autox events....but the pads are little dusty,but thats also because of the slots.
Old May 22, 2008 | 11:05 PM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duck Sauce &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering what kind of brake setups you guys are running for daily driver/occasional spirited driving use?</TD></TR></TABLE>
My Setup - https://honda-tech.com/zerothread/2248376
To bad the car's sitting without a power plant right now...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duck Sauce &raquo;</TD></TR><TR><TD CLASS="quote">Where's a good place to order brake parts from? </TD></TR></TABLE>
http://www.importrp.com
egvtec
Suspension & Brakes
Feb 15, 2010 07:07 AM
xintegr
Jun 19, 2007 01:12 PM
Silent9o8
Suspension & Brakes
11
Dec 26, 2005 07:38 PM
Eucalyptus lude
Oct 6, 2004 04:06 AM
::MYCORD::
Jul 11, 2004 03:00 AM
