timing belt from advance?
Old May 21, 2008 | 03:39 AM
mattbatson's Avatar
Default timing belt from advance?
I did a search, but didnt see an answer...
Is the stock motor on my 94 civic an interference motor?
If it is....
Should I buy my timing belt from the dealer and not risk using an advanced auto one?
Same question for the water pump...
Also, is it smart to just go ahead and replace the tensioner while I'm in there?
The car has 185K on it
Old May 21, 2008 | 04:26 AM
starion88esir's Avatar
Default Re: timing belt from advance? (mattbatson)
You always replace the tensioner when you replace the belt. You should be fine with an autozone belt. The engine is an intereference engine.
Old May 21, 2008 | 05:19 AM
h2392si's Avatar
Default Re: timing belt from advance? (starion88esir)
You can sometimes find a good deal on OEM parts package deals (timing belt, waterpump) on ebay. Check it out, definately worth a look. I would not use that Autozone stuff for important parts such as this. Good luck.
rodondoaccord
15
Mar 30, 2014 05:28 AM
pli
Sep 29, 2007 04:58 PM
VTECth1s
May 5, 2007 08:14 AM
domepizzle
Jun 11, 2003 08:34 AM
