this may be a silly ?
Old May 21, 2008 | 12:30 AM
cdg92eg's Avatar
Default Big Brake conversions?
Does any one know who makes a bige brake conversion for an ek body style with integra rear conversion? Not a whole caliper swap...but the brackets and larger rotors?
Modified by cdg92eg at 1:35 AM 5/21/2008
Old May 21, 2008 | 02:45 AM
newby_j's Avatar
Needs More Cowbell
Default Re: Big Brake conversions? (cdg92eg)
talk to "brakeexpert" on here. he can hook you up
Old May 21, 2008 | 08:09 AM
kaiba's Avatar
So you want big brake in the front and rear?
Old May 21, 2008 | 08:57 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdg92eg &raquo;</TD></TR><TR><TD CLASS="quote">Does any one know who makes a bige brake conversion for an ek body style with integra rear conversion? Not a whole caliper swap...but the brackets and larger rotors?
Modified by cdg92eg at 1:35 AM 5/21/2008</TD></TR></TABLE>
You want something bigger than Integra or 99-00 Civic Si front brakes?
Old May 21, 2008 | 09:52 AM
kaiba's Avatar
Is this what you're looking for.
http://fastbrakes.com/shop/pro...d=111
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastbrakes.com &raquo;</TD></TR><TR><TD CLASS="quote">11 inch front upgrade using OEM style calipers and rotors. Kit comes complete with 11 inch slotted & drilled rotors, remanufactured OEM calipers, performance brake pads, front braided steel brake lines. NOTE: Must use 15 inch or larger wheels, factory wheels will fit. Calipers require slight modifications. Fits Del Sol 1996-2000 Civic with 9.5" brakes</TD></TR></TABLE>
Old May 21, 2008 | 09:56 AM
kaiba's Avatar
Default Re: Big Brake conversions? (kaiba)
Or are you refering to AEM big brake kit using factory caliper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AEM &raquo;</TD></TR><TR><TD CLASS="quote">AEMs Big Rotor Brake Kit allows for use of the Original Equipment (O.E.) brake caliper, making it the most affordable big rotor system on the market. AEMs rotors have an average 20-percent larger surface area and can reduce a vehicles stopping distance by up to 33 percent. These oversized rotors also increase brake torque for reduced pedal effort and have a greater thermal capacity that extends performance during continuous hard braking. Venting and drilling was a key consideration in the engineering process of the rotors and ensures maximum heat dissipation for reliable, consistent braking. The utilization of CNC-machined 6061-T6 billet aluminum rotor hats diminishes the rotors tendency to cup under extreme prolonged use and reduces the overall weight of the rotor when compared to cast versions. The AEM Big Rotor Brake Kit includes brake caliper repositioning brackets, complete Premium Grade and aircraft-quality hardware, comprehensive instructions and AEM decals. </TD></TR></TABLE>
Old May 21, 2008 | 11:27 AM
newby_j's Avatar
Needs More Cowbell
i did the cl calipers and re-drilled prelude rotors on dx hubs setup.....it is amazing!
mikeybee95
Jun 17, 2015 06:26 AM
turbo_b16_ex
Nov 13, 2006 11:59 PM
silentdeath12886
Sep 15, 2006 03:24 PM
mp5o
12
Jul 14, 2005 04:13 PM
Bimmerman
Apr 27, 2005 05:03 AM
