LS FD in 99+ Si Trans
Old May 20, 2008 | 11:40 PM
CaseBone's Avatar
Default LS FD in 99+ Si Trans
My buddy is putting a tranny together for me and I was wondering if a 99+ Si transmission with a LS differential with FD gear would be a decent tranny to use. I will be tracking this car about 3 times a year hopefully more. I will be making 400+whp and driving the car daily. I was just seeing what you guys thought and what it'd be in comparison to. Like would it be longer than a GSR trans after the LS FD swap or no?!
Thanks
Old May 21, 2008 | 02:19 AM
DaveF's Avatar
Default Re: LS FD in 99+ Si Trans (CaseBone)
here is a gear calculator that will allow you to see differances between the 2 before you start gettin your hands dirty. http://autocrossing.com/cgi-bin/gearcalc.cgi
dont try to put the ls ring gear in there without swaping the pinion gear (at the bottom of the countershaft) the teeth on the 2 pinion gears have differant spacing. ( at the bottom of the countershaft)
Old May 21, 2008 | 05:11 PM
racin jasin R's Avatar
good question!
Old May 21, 2008 | 08:37 PM
96Spec Ek's Avatar
Default Re: LS FD in 99+ Si Trans (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">
dont try to put the ls ring gear in there without swaping the pinion gear (at the bottom of the countershaft) the teeth on the 2 pinion gears have differant spacing. ( at the bottom of the countershaft) </TD></TR></TABLE>
He would be replacing the entire countershaft then right?
Old May 21, 2008 | 09:20 PM
building boost's Avatar
Default Re: LS FD in 99+ Si Trans (96Spec Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Spec Ek &raquo;</TD></TR><TR><TD CLASS="quote">
He would be replacing the entire countershaft then right?</TD></TR></TABLE>
yes because the ls countershaft has the same amount of teeth as the b16/gsr countershafts but the teeth profiles are different.
Old May 21, 2008 | 09:56 PM
CaseBone's Avatar
Thank you DaveF. I knew there was a calculator somewhere! But yes I forgot to say I was going to swap the pinion gear as well. I was just more focused on what the results would be!
oleshifty
Transmission & Drivetrain
Oct 5, 2011 10:19 PM
boostedteg1203
Nov 15, 2009 07:23 PM
IanB
Oct 13, 2008 04:40 PM
civic2slo
Mar 5, 2005 06:06 PM
tegasaurus
Dec 14, 2003 08:11 PM
