torque specs on arp hardware
what is the torque specs on these things
apr main studs
apr 2000 rod bolts for eagle rods
arp head studs
they are tightened down to stock specs right?
apr main studs
arp head studs
my ARP rod bolts are torqued down to 27ft-lbs. they say to tq them down 3 times to 27ft-lbs and loosen them each time but do not loosen them after the 3rd time.
Depends if they are 5/16 or 3/8 ARP bolts. Eagles came with both and they have different TQ numbers. Get the correct info from ARP, not the wrong info frome here.
That's what I though cause I remember reading this
http://www.arp-bolts.com/Tech/TechTorque.html
And the 8mm are 26 ft./lb. and the 9mm are 40 ft./lb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">That's what I though cause I remember reading this
</TD></TR></TABLE> And Eagle rods use 5/16 or 3/8 bolts, not 8mm or 9mm bolts and nuts. 4 different things. 4 different TQ numbers.
H22coupe
Apr 30, 2004 05:24 PM
