PG7 ecu
Old May 20, 2008 | 06:21 PM
whiteknightef's Avatar
Default PG7 ecu
Hey I just found a PG7 ecu for like 5 bucks at a local yard. I was wondering if anyone knew the specs right off hand. I forgot what exactly the compatibility was with an A6 as well. Is it plug and play?
Old May 20, 2008 | 07:47 PM
Default Re: PG7 ecu (whiteknightef)
come on guys i need to know if this is plug and play , and I need help remembering the specs. I have searched all day!
Old May 20, 2008 | 09:26 PM
well thanks for nothin
Old May 20, 2008 | 11:43 PM
Tyson's Avatar
its plug and play, but the casings are different. you need to put it in a EF casing to have it bolt down. itll fit right in tho with the PM6 casing.
it allows 300 more rev limit. but it doesnt offer any more power than a PM6. PM6 is more horsepower.
Old May 21, 2008 | 01:43 AM
LANCEalot's Avatar
i think i prefer the p28 its better =D
Old May 21, 2008 | 06:46 AM
jlicrx's Avatar
PG7 was used in 86-89 Integras - the 86-87 Integra used a vacuum advance ignition system where the 88-89 used electronic advance - the 86-87 PG7 will <U>not</U> work with the 88-91 CRX/Civic MPFI engines - <U>only</U> the 88-89 will work - either one will plug right in
this is 86-87 PG7 ECU
this is 88-89 PG7 ECU
Old May 23, 2008 | 07:29 PM
jdm_ef9_b16's Avatar
the pg7 i had in my car didnt look like that, and it was alot better than the pm6 that came in my car,. it gave me more than 300 more rpms. plus the fuel was better. and i didnt have to change anything. i even used it on my sohc vtec swap.
buffgsr
Honda S2000
Jul 6, 2007 12:48 PM
hatchback_al
Nov 27, 2004 09:31 PM
shylilpimp
Oct 23, 2003 05:29 PM
