Really Bad Camber?
Old May 20, 2008 | 04:31 PM
Integritycaptain90's Avatar
Default Really Bad Camber?
So i hit a curb last nite...... and as you may already know my alignment was way off,... took it to sears and had a re-alignment done but they told me nothing was bent,. my camber is still off bad! i believe i may need either tie-rod ends or a lower or upper control arm, any suggestions
Old May 20, 2008 | 04:52 PM
AccordVT's Avatar
Default Re: Really Bad Camber? (Integritycaptain90)
Check your upper control arm, the upper ball joint may have been damaged, the control arm mounts/bushings may have been damaged or the arm itself bent. The lower joint may also be damaged but is less likely to cause camber issues then the upper. Jack up the car and put it in gear; grab the tire and torque on it, see if it clunks or wobbles.
Old May 20, 2008 | 04:53 PM
SuShiBoiiii's Avatar
do you just have bad camber wear? pulls to a certain side?
Old May 21, 2008 | 07:44 AM
professorman's Avatar
Default Re: Really Bad Camber? (SuShiBoiiii)
Take it back to them if it is not within the factory specifications. Is the suspension modified? If you get an alignment done, it should be withing factory specifications, if not, they should be able to tell you why they can not get it within the specifications.
Old May 21, 2008 | 10:35 AM
Default Re: Really Bad Camber? (professorman)
no the car is definetly not within spec... i had reason to suspect it was a control arm issue, i think the guys at sears are dumbasses, theirs gotta be something bent, the car pulls hard to the right(passenger)side which was the side i curbed it on
Old May 22, 2008 | 06:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integritycaptain90 &raquo;</TD></TR><TR><TD CLASS="quote">no the car is definetly not within spec... i had reason to suspect it was a control arm issue, i think the guys at sears are dumbasses, theirs gotta be something bent, the car pulls hard to the right(passenger)side which was the side i curbed it on</TD></TR></TABLE>
When I lowered my car, my lifetime warranty at Firestone was $h!*. I did it with them about 5 times, then finally, my mechanic friend suggested I go to a guy he knows at Kramer tire. He got everything perfect for me after that.
Blacksole
Nov 15, 2011 08:40 AM
scorpion-stinger
Apr 17, 2009 09:59 AM
ChevelleSSLS6
Mar 10, 2009 01:05 PM
..::91TEG-G2::..
May 23, 2004 01:53 PM
vtecvoodoo
Jul 13, 2003 11:26 AM
