Bouncing Tech Needle
Old Jul 15, 2002 | 11:14 AM
hybridbmw's Avatar
Default Bouncing Tach Needle
I have a crx with a b16a. I installed a aftermarket autometer tach about 2 months ago, but recently when i get into the higher RPM's (over 6k) the needle on both the autoguage and the stoch tach bounces and doesnt read accurate. My shift light even comes on around 6k sometimes. Has anyone else had these problems? Thanks!
[Modified by speedaholic, 2:00 PM 7/15/2002]
Old Jul 15, 2002 | 11:26 AM
SuperCivic's Avatar
Default Re: Bouncing Tech Needle (speedaholic)
sounds like the ignitor to me!
Old Jul 15, 2002 | 11:32 AM
crxtreme27's Avatar
Is the engine performance affected too??? If not, open up the distributor and clean it up, specially all the wire connections.. the same thing happened to my friends car. If it does affect the engine its very likely that your rotor is bad. The same exact thing happened to me, it was just a bad lose rotor.
Old Jul 15, 2002 | 11:40 AM
REDBARON's Avatar
First check you connections at your distributor. Make sure the wires are securely in the connectors. But it has to do with your distributor. I believe your ignitor may be going out.
Old Jul 15, 2002 | 12:16 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Bouncing Tech Needle (REDBARON)
tighten connections at the ignitor.
problem solved.
Old Jul 15, 2002 | 12:59 PM
hybridbmw's Avatar
Default Re: Bouncing Tach Needle (two.oh)
Thanks for the help guys. I will check it out tomorrow and see if i can fix it. Thanks again!
s13hero
31
Jun 17, 2016 06:43 AM
usafhanda
Mar 14, 2012 10:29 PM
blacksheep
Oct 13, 2002 10:08 PM
customx_
Jun 18, 2002 11:30 PM
B6teen
Nov 12, 2001 11:20 AM
