I NEED HELP CHOSING PISTONS & RODS 4 GRS ALL MOTOR !
Old May 20, 2008 | 01:46 PM
Nuxinator's Avatar
Default I NEED HELP CHOSING PISTONS & RODS 4 GSR ALL MOTOR !
well so far i have :
-95 gsr block stock
-oil filter relocater
-moroso high performance oil cooler
-moroso oil breather-catcher
-TOTAL SEAL FILL-2-FIT MOLLY RING !
-b16 pr-3 head ( street port ) myself
-p-73 intake manifold ! ported by port flow
-type-r valve springs
-buddy club cams spec lV ( i think there stage 3 )
-buddy club cam gears
-buddy club reprogramable ecu
-Jasma 4-1 headers
-toyota supra 440 injectors
-ctr pully
I WANNA BE NITROUS READY AROUND 100 SHOT ! 25 PER CYLINDER.
I WOULD LIKE TO ACCOMPLISH 300+ HP ON 91 OCTANE
SO WHICH PISTON COMPRESSION ?
WHICH ROD & PISTONS SHOULD I GO WITH ?
SHOULD I CONSIDER POWDER COAT PISTON FACES AND RODS
HELP ME WITH UR OPINIONS PLEASE !
Modified by Nuxinator at 5:21 PM 5/20/2008
Old May 22, 2008 | 08:38 PM
sgt.rosenfield's Avatar
Default Re: I NEED HELP CHOSING PISTONS & RODS 4 GSR ALL MOTOR ! (Nuxinator)
jhpusa has a pretty good deal for supertech pistons...forged rods are pretty much all the same just look for a good deal on some h-beam (I prefer h-beam, most people say there is no real diff. I can't find any real testing of mechanical stressing and what not). If your only running a 100 shot and not going over 82mm bore you could get away w/ stock rods as long as you have them looked at and they are in good condition (could have them shot peened).
Nuxinator
May 21, 2008 08:45 PM
Nuxinator
11
May 20, 2008 06:39 PM
Nuxinator
Engine Management and Tuning
May 20, 2008 02:35 PM
eddiecut
Aug 27, 2002 10:07 PM
