help on chosing pistons on my ALL MOTOR GSR !
well so far i have :
-95 gsr block stock
-oil filter relocater
-moroso high performance oil cooler
-moroso oil breather-catcher
-TOTAL SEAL FILL-2-FIT MOLLY RING !
-b16 pr-3 head ( street port ) myself
-p-73 intake manifold ! ported by port flow
-type-r valve springs
-buddy club cams spec lV ( i think there stage 3 )
-buddy club cam gears
-buddy club reprogramable ecu
-Jasma 4-1 headers
-toyota supra 440 injectors
-ctr pully
I WANNA BE NITROUS READY AROUND 100 SHOT ! 25 PER CYLINDER.
I WOULD LIKE TO ACCOMPLISH 300+ HP ON 91 OCTANE
SO WHICH PISTON COMPRESSION ?
WHICH ROD & PISTONS SHOULD I GO WITH ?
SHOULD I CONSIDER POWDER COAT PISTON FACES AND RODS
HELP ME WITH UR OPINIONS PLEASE !
-95 gsr block stock
-Jasma 4-1 headers
-ctr pully
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">Pics of port job?</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nuxinator »</TD></TR><TR><TD CLASS="quote">
-95 gsr block stock
most of this is not required and does nothing for power.
b16 pr-3 head ( street port ) myself (no...do not do this)
-type-r valve springs (not going to work with your chosen cams)
-buddy club cams spec lV ( i think there stage 3 ) ("stage" means nothing, they are what they are)
-buddy club reprogramable ecu (is this just a chiped ecu?)
-Jasma 4-1 headers (= stock header. Get a better one if you want to make power)
-toyota supra 440 injectors (overkill. more than likely, stock or 310cc would be enough)
-ctr pully
I WANNA BE NITROUS READY AROUND 100 SHOT ! 25 PER CYLINDER. (that's fine on that levelas long as it's set up and tuned properly)
I WOULD LIKE TO ACCOMPLISH 300+ HP ON 91 OCTANE (on or off nitrous?)
SO WHICH PISTON COMPRESSION ? (10.6 -11.2:1 is fine)
WHICH ROD & PISTONS SHOULD I GO WITH ? (stock)
SHOULD I CONSIDER POWDER COAT PISTON FACES AND RODS (search powdercoating, you obviously don't understand what it is or what it isn't)
HELP ME WITH UR OPINIONS PLEASE ! (done!)
-95 gsr block stock
-ctr pully
ALL STUFF I COLLECTED ALONG THE WAY TO REBUILD A KILLER GSR I WONT USE ALL THAT STUFF ! I JUST WANNA FIGHT HEAT AS MUCH AS POSSIBLE ! I MOST LIKELY WILL DROP IN 83MM PR3 PISTONS CERAMIC COATED ON BLUE PRINT BRAND RODS !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nuxinator »</TD></TR><TR><TD CLASS="quote"> I MOST LIKELY WILL DROP IN 83MM PR3 PISTONS </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nuxinator »</TD></TR><TR><TD CLASS="quote"> ALL STUFF I COLLECTED ALONG THE WAY TO REBUILD A KILLER GSR I WONT USE ALL THAT STUFF ! I JUST WANNA FIGHT HEAT AS MUCH AS POSSIBLE ! I MOST LIKELY WILL DROP IN 83MM PR3 PISTONS CERAMIC COATED ON BLUE PRINT BRAND RODS !
So you're a troll trying to "entertain" yourself with lame comments about random ways to build an engine. Don't you have anything else better to do with your time? Seriously?
</TD></TR></TABLE>So you're a troll trying to "entertain" yourself with lame comments about random ways to build an engine. Don't you have anything else better to do with your time? Seriously?
how is that gonna work
i never seen a gsr intake manifold on a b16 head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LA_HONDAS »</TD></TR><TR><TD CLASS="quote">
p73 and pr3 are the same design. p72 is gsr
EF9_TryMe
Apr 21, 2012 08:10 PM
Nuxinator
Engine Management and Tuning
May 20, 2008 02:35 PM
