B-Series Sensor Confusion
Old May 20, 2008 | 12:00 PM
SlipGear's Avatar
Default B-Series Sensor Confusion
Well i am putting a ls in my EF. I had the b-series harness but some idiot chopped the end off one of the big plugs so....I am trying to use my D-series harness. Everything is fine except i am missing one plug for a sensor. Can someone help me identify this sensor? Also do i have to have it hooked up?
Green Sensor In Middle
Old May 20, 2008 | 05:24 PM
mike9571's Avatar
Default Re: B-Series Sensor Confusion (SlipGear)
No worries you dont need it. Its orignal use has something to do with the A/C system on the integras.
Old May 20, 2008 | 06:27 PM
SlipGear's Avatar
Default Re: B-Series Sensor Confusion (mike9571)
Thanks. I was going to leave it unplugged and hope for the best.
Old May 20, 2008 | 06:45 PM
traxxasx's Avatar
looks like your vtec pressure switch, you need that plug for vtec to work.
Old May 20, 2008 | 06:48 PM
schwinnrex's Avatar
Default Re: (traxxasx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">looks like your vtec pressure switch, you need that plug for vtec to work.</TD></TR></TABLE>
if you read the OP you would see that its an LS, which is a non-vtec engine.
1989through2010
May 20, 2013 01:11 AM
MumblyJoe
Jan 3, 2013 03:46 AM
HondamanXxX
May 23, 2009 09:49 AM
RCautoworks
Aug 1, 2005 10:59 AM
JDM CRX
Feb 10, 2003 09:11 AM
